Go to Post No. This is CD, take the threads and their topics seriously. - pwnageNick [more]
Unread 12-11-2007, 01:01
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: Cool Frame Ideas?
Originally Posted by Qbranch View Post
Watch out!
We tried this stuff and it does look fantastic on paper, but they have a huge issue with being out of square. Well, not the connectors themselves, but what you put together with them. When we tapped our connectors in everything was nice and strong... but horribly out of square.
The robot frame we put together couldn't even hold an axle straight, let alone sit level. Maybe if you used force gauges or something when pressing the connectors in, or had really close tolerancs on the ID of the tube you use it would work... but just a heads up, with your ajax square tube it doesn't look too pretty...
-q
Thank you for the info--I too was hoping that by mentioning EZ Tube, somebody had to have seen it and tried it. Yes, I would imagine that in order to get a box frame that was square, you would have to have the opposite tubing pieces cut with 90 degree squared ends and be very accurate on the lengths since the lengths are controlled by the connectors bottoming out against the ends of the tubing. Keeping it squared up could probably be helped with some thin aluminum gusset strips and rivets, but now it's not so EZ.
Now that I've had time to look, the 80/20 system and the EZ Tube system look very similar, at least in concept, even with the availability of extruded tubing with panel-mounting flanges. EZ Tube connectors seem longer and have the option of the steel-core reinforcement (probably adds too much weight for a robot frame...probably).
Of course, if you're not worried about reusing the connectors, you could always use standard thin-wall 1" tubing and some two-part epoxy like JB Weld.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
the frame kaboose Technical Discussion 7 11-01-2007 22:38
Riveting up a frame Billfred Technical Discussion 27 19-12-2006 19:49
Cool new ideas for FIRST Robots - who has them? sanddrag General Forum 44 04-08-2005 15:02
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
