Go to Post rumors only beget more rumors - JakeGallagher [more]
Unread 12-11-2007, 13:26
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: thoughts about image processing
Originally Posted by 3dude_2231 View Post
Tim, you said that the CMUCAMs aren't so great for a starting point,
but you didn't mention what would be, is a standard webcam better?
Yes, a webcam with a desktop or laptop would be a better setup to learn actual image processing. The development and debugging cycle would be some much faster and simpler than using a small system where you have to continually develop on a bigger computer anyhow, download it to the target, and have very limited debugging capability. Not to mention the limited memory and processing power. Image processing can be very memory and compute intensive and for the educational part you probably don't want to skimp on either. Once you learn, then you can port it to a small system.
I was thinking more in the sense of using the cam with a smaller controller,
(such as a large PIC), if that's my larger objective, where should I start?
One alternative to the CMUCam that I know of for small systems is the AVRCam. It's inexpensive and you can play with its programming. I believe it uses the same camera module that the CMUCam uses so you could potentially save that cost as well but you need to verify that. The toolset to program it is free as well. A lot of the people in the Silicon Valley Homebrew Robotics Club use AVR instead of PIC for their bot controllers.
http://www.jrobot.net/Projects/AVRcam.html
Thoughts about future autonomous scoring... JimGRobot Programming 12 04-04-2007 00:01
Critique my image processing program... Salik Syed Programming 13 29-06-2006 16:57
Thoughts about the future FIRST games David55 General Forum 7 24-05-2006 00:34
Just some thoughts about FIRST I had while trying to fall asleep during build season Racer26 General Forum 31 20-03-2004 11:27
