Go to Post Corndog is the new water game. - Basel A [more]
Unread 08-11-2007, 12:45
neroc neroc is offline
neroc is an unknown quantity at this point
Unhappy cmucam1
hi everyone,
sorry if ask for the old question....
i'm newbies in cmu cam field....
actually, i haven't enough budget to develop my final project....
at least this cam can be able me to play with the vision camera.....
how to use gui software for this kind of camera?
anyone can help me....
Unread 10-11-2007, 06:59
Re: cmucam1
anyone wouldn't help???
give me some guide please....
Unread 10-11-2007, 16:43
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: cmucam1
What are you trying to do with the cmucam?
Are you trying to get it to track a light?
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 11-11-2007, 09:02
Re: cmucam1
i want to track the ping pong ball.....so i want it know that a ping pong ball....the ball yellow coloured...
Unread 11-11-2007, 13:57
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
Re: cmucam1
You can use the CMUcam in just about any project.
1) The big 9 pin D shaped connector can hook up to the serial port of a PC and you can send and recieve command and data using Hyperterminal, (in Windows-Programs- Accesories-Communications) or another terminal program,like TerraTerm.
2) You hook up like in 1), but use a GUI, try the IFIRobotics page for the camera. Go here and download "CAM2 Getting Starting". Everything you need is there including the manual.
3 Use the TTL port connector, black 4 female pins next to 9 pin D connector.
Use this port to talk to it with another uController. I use a BasicStamp to cause it to track a blue light. This port talks serial at a baud rate set by jumpers on the CMUcam (top row of male pins, look in manual for setting).
Basicly, once the camera is initalized, giv it a "TC" command with teh RrdBluGreen values to track, and it will send back a packet, telling you where the target is located, x & y, in it's field of view. You can use those values to move the robots drive motors untill the target is centered.
Unread 11-11-2007, 15:00
Re: cmucam1
emmm... i will try out your step....
but i wonder, could be cmucam2 gui is appropriate with my cmucam version 1...
if could, what type of suitable packet to use?
Unread 12-11-2007, 00:57
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Re: cmucam1
Im confused. Are you using the CMU cam for your robot, or for a side project?
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 12-11-2007, 17:38
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: cmucam1
I don't think he's on a robotics team, so technically it's not a side project
neroc: Search the forums, read the manuals. If you can't get it working, post very specific questions which we can answer.
One question from me to you, are you using a programming environment such as EasyC or MPLAB?
Need.. More.. Info...
-Nathan
Save money with PriceWombat, a shopping comparison and price tracking tool (that I made!).
Check out my hobby electronics business!
My former robotics team: Huntington County 4-H Robotics
Unread 12-11-2007, 18:24
Re: cmucam1
i'm using MPLAB IDE....
ok i will find out my specific problem....
but i'm still blur whether all technique in cmu version 2 could be implement to cmu version 1?
Unread 12-11-2007, 21:47
AKA: !!Mitch!!
FRC #1392
Re: cmucam1
ok.. cmucam1... are u talking about the older version ... newer version....is this even from ifi robotics KOP?? or did u just buy it off ebay?
Unread 12-11-2007, 22:08
FRC #1277
Re: cmucam1
Actually, I think software-wise version1 and version are the same. The new, version 2 that came with last years kit, doesn't have all the connectors installed, but does have RS232 & TTL serial connectors.
Unread 16-11-2007, 11:22
Re: cmucam1
yes the older version...that was make me dumb....
Unread 16-11-2007, 11:26
AKA: !!Mitch!!
FRC #1392
Re: cmucam1
K just wondering..
the older version of the cmu cam isnt much different from the 2nd version. The only big difference is the pwm outputs. Someteams hooked these into their victor motors, and the robot went nuts and could not be turned off.
As with programming. There is no difference between the two. Both are programmable using the same language in MPLab.
What code are you using?
Unread 18-11-2007, 21:48
Nathan's Avatar
Re: cmucam1
If you want to, you can get Kevin Watson's code for the CMU cam here: http://www.kevin.org/frc/
There's also tons of documentation on his site.
-Nathan
Unread 08-12-2007, 14:55
Re: cmucam1
hallo everyone....
i'm back.....
i have the question about the command...
1. when send TW and then TC command it send back the M data packet, it's that ok using only one type data packet?
2. Where we can get the TC parameter which is the max/min value of red, blue,
green.
3.in my understanding the initial target of object only when the TW command is send, and it will only refer to the output of TW command as a reference to track the target. Am i correct?
4. Could someone tell me the alghoritm how the cmu operate when interface with PIC?
