Go to Post Having someone with as much mainstream appeal as will.i.am is a great strategy to draw large amounts of attention to a program that has been relatively hidden to the masses. - Karthik [more]
Unread 11-11-2007, 23:08
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Silicon Controlled Rectifier
Hey i am currently building a circuit and several websites have suggested to use an SLR. My question to you guys is, What is a Silicon Controlled Rectifier? What is it's sole purpose within a circuit?
Thnxs
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 11-11-2007, 23:45
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Silicon Controlled Rectifier
An SCR is kind of similar to a transistor, yet significantly different. An SCR acts like an electronic switch, that once a current is applied to the gate, current can flow through anode and cathode until the current is removed from the entire device, compared to a transistor where the current has to only be removed from the gate.
Unread 12-11-2007, 00:12
What are you making that uses an SCR? Something high(ish) voltage?
Think of an SCR as a transistor that feeds itself. This allows a tiny control signal to activate it, but it means that you can't turn it off at the gate - something else needs to cut the current off.
This means that it has a lot of transistor like properties. Most importantly, its dissipation mode is a voltage drop - this makes it good for high voltage applications.
Please let us know what you are up to, it sounds interesting.
Unread 12-11-2007, 00:50
AKA: !!Mitch!!
FRC #1392
This year our robotics team could not afford to take part in FIRST Robotics. So we divide our team into two. Our group is building a EM Gun. Its going to be a 3 stage coil gun using #23awg copper wire. Our barrel is a aluminum hallow shaft measured at 3/8 of an inch. Im still trying to work out the numbers and schematics but everything takes time and research I am going to be using voltages around 350-400 and SLR's are apparently really good at controling and switching these high voltages and ampere's.
Unread 12-11-2007, 08:32
An SCR is a silicon controled rectifier. This particular type of device can act as a switch and can be turned on with a very low control voltage but as it's name implies (and it's schematic symbol shows) it can only control current in one direction. It's other failure is once turned on, it cannot be turned off without removing the power that it turned on. This charachteristic while it sounds bad works very well in controlling pulsed DC power or in acting as a phase controled switch on AC power. It actually makes an interesting power supply when used in a bridge configuration. It's AC version is a triac and those are sued in virtually every light dimmer in use today.
Unread 12-11-2007, 09:26
I thought it might be something like that.
A word of warning - be careful when paralleling these devices. Add a small resistor to the gate of each SCR. This will prevent the gates from "ringing". Gate ringing destroyed my friend's coil gun that used SCRs. To over simplify, gate ringing causes the SCRs to turn on and off very very rapidly.
Also, I'm not sure if you need to add a ballast resistance to spread the current over multiple devices. Can someone verify this?
Unread 12-11-2007, 10:03
in between teams
AKA: Luke Van Oort
While SCRs can work for you application, I'd only use them in a single coil coilgun design. MOSFETs or IGBTs are probably a better choice since you can turn them off. Also, don't forget to put a diode across each coil so that you don't fry your electronics from the current generated when the field collapses.
Team 1219: 2009 - Mentor
Unread 12-11-2007, 18:21
AKA: !!Mitch!!
FRC #1392
What type of resistor would i use>? 10 ohms? or like 10 million ohms?
Unread 12-11-2007, 20:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
As far as your barrel material, you should remember that metals conduct and thus will generate eddy current opposing the magnetic field of your coil and robbing you of some power. There a few ways around this, but I'll leave that for you guys to discover.
You could use SCRs if you powered each coil separately, which I think you'd be doing anyways. I think starting with SCRs would be a safer bet than IGBTs since they'll stay on until they've dissipated all the energy in the caps. This would reduce your rate of fire since you'd have to recharge from zero every shot, but you wouldn't have to worry about a charged cap wanting to kill you after a firing.
Also, it's highly important to understand the purpose and placement of the extra resistor and diode you'll be adding. The coil of the gun is basically an inductor, and will be trying to keep a constant current going through it. Once your cap is spent, the constant current from the coil will act to charge it in the negative direction, which is baaad for the polarized caps you'll be using. So the idea is to re-route this current through a diode and resistor to dissapate the energy stored in the coil. The circuit would look something like:
           SCR
      Resistor Z   3
Cap            |   3 Coil
         Diode ^   3
The size of the resistor depends on how quickly you want to dissapate the energy, and how large a voltage differential your circuit can handle. The maximum current going through it is determined entirely by your coil's inductance and cap's size. After that, Ohm's law will tell you what the voltage drop across it will be and how many watts it will dissipate at this peak current.
Unread 12-11-2007, 21:04
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Silicon Controlled Rectifier
This site may help with your project.
http://www.powerlabs.org/index.html
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 12-11-2007, 21:09
AKA: !!Mitch!!
FRC #1392
Awesome.. im gonna wrap my mind around this for a couple of days. Im not that logical so it will take me a while. I will be posting my circuits within a fews days. It would be wonderful if any of you could lend suggestions.
thnxs
keep posting if you theres an easier way to explain either the SCR or bleeder resistor.
Unread 12-11-2007, 22:17
AKA: !!Mitch!!
FRC #1392
Hey! actaully... i think i somewhat understand this stuff guys below are two photos that i scanned just recently.. let me noe if this makes any sense before i blow myself up
NOTE* You will have to save the pictures and rotate/resize them. Srry any inconvenience.
Charging Circuit:
http://server6.theimagehosting.com/i...20Circuit2.JPG Circuit2.JPG
Fire Mech:
http://server6.theimagehosting.com/i...&public_view=1 Mech.JPG
C1 and C2 are basically linkers between the two separate circuits.
My power supply, Transformers, and capacitors are a big unknown question mark...?????? so again ... as mentioned before im still working out the numbers
NOTE* ifthe images are really unreadable... then let me know i'll rewrite and scan them with a better dpi
Unread 12-11-2007, 22:42
1. The cap goes between C1 and C2. When you're firing, you want high current provided by a high voltage through a low resistance. Your HV power supply couldn't supply the current on its own, so you charge up a cap and use it as a source of high current (for a very short time). Ideally, you disconnect the HV power supply from the cap just before you fire so the power supply doesn't melt trying to supply that kind of current.
2. You can trigger the SCR directly from the anode. That is, if you had a switch (with a resistor in series) connecting the anode to the gate, and you closed the switch, your coil would fire. Of course if you're serious about a multi-stage coil gun, you'd be triggering the SCR with yet other solid state devices like some transistors, etc.
Unread 12-11-2007, 23:05
Can you please post the part numbers you are proposing? I couldn't read them very well in the jpg.
I'm not sure what all the diodes next to the coil are for. You just need a single diode in anti parallel to the coil.
If you are using a single SCR, you can ignore what I said about ballast resistance. Just the gate resistance is necessary.
Unread 13-11-2007, 15:03
Mitch,
The diodes in series with the coil are redundant and everything looks to be in the wrong polarity to allow current flow. The capacitor that is wired in series with the coil will form an LC circuit which will modify the resultant current in the coil. Also be advised, that fire switch and battery will be elevated to the supply voltage if and when the SCR fires.
PC Controlled Robot EHaskins Programming 6 05-11-2006 06:45
Camera Controlled Robot douglass1371 Programming 1 19-02-2006 19:22
Victors Controlled By Joystick Buttons douglass1371 Electrical 2 17-02-2006 01:57
Net Controlled Lighting Mike Chit-Chat 5 08-03-2005 20:06
Servos controlled by RC? Obi Programming 5 01-02-2005 14:43
