Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 13-11-2007, 00:31
Billfred's Avatar
Billfred Billfred is offline
Re: Ribbit Rivet...
Originally Posted by Gdeaver View Post
Our team used the rivets mentioned last year on the kit bot frame. They held up well and my subjective feeling is that it was a little stiffer.
I'll ask, since nobody else has; what kind of rivets were you using in the frame?
I shopped around Grainger (since there's a warehouse here in town) and found a few potential options:
5LE49 - 1270 shear/830 tensile, $8.86/25. (Aluminum w/ aluminum mandrel)
5LE56 - 2400 shear/1850 tensile, $10.40/10. (stainless/stainless)
5LE53 - 2400 shear/1850 tensile, $7.45/25. (steel/steel)
4AR31 - 1270 shear/1550 tensile, $7.01/100. (steel/steel)
The hitch with 4AR31 is that the material thickness only goes up to 0.250". While that's on the money for the kit frame (in theory, since you're joining two 1/8" pieces of metal next to each other), it would seem like going to ones with 3/8" grip range (which all the rest are) would give us a bit of breathing room.
No small part of my motivation to try rivets stems from what Kevin noted: it's a pain in the butt to get to some of those nuts, particularly once you've got the rest of a robot on board. It became the job of one of the kids at each event to check each nut and bolt and tighten as necessary, and Ron Karpinski still handed me a fistful of nuts and bolts at BE.
Greg Needel was talking with me the other night on the subject, and he was a little wary of going all rivets. He threw in the idea of leaving one bolt in on each end of the connections to soak up some of the shear loads. While I'd still take zero bolts over non-zero bolts if it does the job, checking 12 or so bolts sure seems a lot easier than checking the (if I counted right) 72 on a standard kitbot.
1618 is getting the riveter Don linked to, though the team is currently on a Thanksgiving hiatus until the 28th. I'm hoping we can get some knowledge before the holidays, or at least before Kickoff.
Unread 13-11-2007, 07:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Ribbit Rivet...
Correct me if I'm mistaken, but going all rivets on the kitbot like this isn't a permanent solution even for a season, is it? Just bring the screws and nuts along, and barring a catastrophic failure in a match, you can always drill them out and put bolts back in fairly easily within a match or two, correct?
If you can't replace the rivets in an hour or two.... well isn't that the point?
Unread 13-11-2007, 08:05
Gdeaver Gdeaver is offline
FRC #1640
Re: Ribbit Rivet...
We used rivets from Mcmaster-carr. Part # 97519A653. I would caution riveting right from the beginning. If you make a mistake and need to drill out the rivets, it's a pain. We put the frame together with bolts and riveted after we were sure of the dimensions. There are higher strength rivets available, but they are very very difficult to remove. For the last couple years we have used the kit frame and riveted 1 x 1/8" 6061 angle on to the KOP base. It has been very effective. Our team lis low on skills, money and machining ability. It worked for us. Last year it took the students forever to build the frame. This year we are going to use the 8020 quick frame. It realy is quick to build a frame.
Unread 14-11-2007, 07:48
FRC #1640
Re: Ribbit Rivet...
One more detail on the 1/4" rivets. We did not use back up washers. It is a real pain to get them on inside the frame. If they are not held perfectly flat against the inner wall you will have a bad rivet joint. On the 1" angle 1/8" rivets we always use backup washers. They are critical to a good lasting riveted joint. We have not had a steel backup riveted joint fail in 4 years of using rivets. However, a couple joints were accidentally done with AL rivets and those joints did loosen up.
Unread 24-01-2008, 21:00
Billfred's Avatar
Re: Ribbit Rivet...
Alright, a bit of an update on the matter.
We tried the Harbor Freight riveter. It failed; the riveter could not reliably hold onto the mandrel when we needed it to and release when we needed it to. After struggling through two riveters' worth of jams and stripped threads and frustrations, we switched to the Marson Big Daddy Riveter (the name of which has already become a running joke within the team) today, and knocked it out in about a half-hour. It's so smooth and easy to work with, it made me genuinely giddy. That riveter runs about $100, but it's some of the best money the team has spent all season. The Grainger part number is 4Y128; on McMaster-Carr, it's 90239A510.
We started with steel rivets, but a bit of consultation with some folks (along with worries as to whether it was the rivets that were causing our riveter issues with the Harbor Freight unit) led us to switch to Grainger part 4Y031, aluminum rivets with an aluminum mandrel and grip range right up to .250". With all the rivets in place, the frame feels fine--maybe even better than last year's with the absence of all the little wiggling that happens with bolts.
We'll be building our drivetrain over the next week (maybe this Saturday if the AndyMark order gets in, which we're doubting); we'll know more about how they hold up as build season rolls on.
Unread 24-01-2008, 21:31
President, VEX Robotics, Inc.
Re: Ribbit Rivet...
Ahhh, my favorite subject: Rivets.
We use rivets (pop rivets) on every joint on our robot that connects to sheet metal. Even items that need to be disassembled quickly are held together with rivets. I swear by them. We use 5/32" and 3/16" aluminum rivets with aluminum mandrels. We also use 3/16" alimunim rivets with steel mandrels in certain high load areas. We have used a total of 20 of these "high load" rivets in the last 3 years (2005, 2006, and 2007). We are not using any steel rivets this year. We have approximately 2,500 rivets on our robot this year.
I challenge anyone using a nut and bolt to disassemble and reassemble your bolted joint to beat my students in a timed race with us using rivets. We use a pneumatic rivet gun from Harbor freight. They are a whopping $24 each. They last about 3 seasons and then you have to get new ones.
Attached is our gun in action on a previous robot.
I do not think you need steel rivets, but I have no test data to back that up. I can tell you this: we have never failed even one rivet on our 2005, 2006, or 2007 robots.
Name:	Riveting the Shuttle Assembly.JPG
Unread 24-01-2008, 21:58
Re: Ribbit Rivet...
We're going with rivets on the kit frame as well and wherever I can convince students it's simpler. Oddly, we're using the harbor freight riveter and we aren't having any issues aside from and operator error tonight. I think it's important to make sure you're using the right tip and that the internal spacing is correct since that affects the jaws clamping, releasing, etc.
Our frame feels pretty good, but I was a little concerned in a few places. We've drilled a few extra holes to fill with rivets to add a little strength. I'm mostly concerned with the lack of precision in the kit frame. There's a distressing amount of slop in all the joints, such that only two out of the three sides of joint are being properly clamped. The third side ends up with about a 1/16th gap that the rivet won't clamp up, so rivets on the side aren't going to do much against shear loads. Or much of anything, really.
Also, to Paul, do y'all use the rivet gun in the Pits? If so, are you bring in a compressor/etc. or do you have some other solution?
Unread 24-01-2008, 22:01
Re: Ribbit Rivet...
We use the riveter in the pits. We bring a pancake style compresor that is sold at Home Depot or Lowes. It is the same compressor finish carpenters use for their finish nailers.
Unread 24-01-2008, 22:35
FRC #1640
Re: Ribbit Rivet...
Glad you guys are having good luck with the rivets. They have been a very successful method for our team since 2002. One more tip. When drilling for the 1/8" rivets we use double end short drill bits that are typically used by sheet metal duct fabricator. They drill aluminum well and when the bit dulls just flip it. Once again we have never had a riveted joint fail. About 4 joints over all those years loosened a little.
Unread 27-01-2008, 10:31
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Ribbit Rivet...
Billfred, we also had similar issues with the Harbor Freight riveter - it wouldn't let go of the mandrel after popping the rivet.
We fixed it with a liberal application of grease to the gripping jaws. After removing the outer tube, we also unscrewed the inner tube. Some grease on the jaw outsides and they were reinserted, along with the spring, and tightened. Then we added a healthy dollop of grease to the inside of outer tube (and got it all the way in to the bottom, maybe 1/2" deep, around the screw in nose-piece) and screwed it all together - now it works like a charm.
You definitely get what you pay for.
Don
Unread 27-01-2008, 10:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Ribbit Rivet...
I add a little twist to that old phrase:
You usually don't get what you don't pay for.
Anyways, thanks for the rivet gun lube instructions, that is something I never though of and sounds very helpful!
We've had lots of small rivets fail, but we use them where we shouldn't, and we also use them as sort of a safety valve....the little rivets break off instead of letting the mechanism get bent up.
Billfred's Avatar
Re: Ribbit Rivet...
Lubrication could well be an issue with the HF riveters, now that I think about it--over the multiple times I disassembled it, it appeared that there was only just enough lubrication to get your hands messy.
Of course, to fix that would involve getting the kids away from the Big Daddy Riveter. That might be a task.
Unread 29-01-2008, 14:22
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Re: Ribbit Rivet...
I challenge any team to build their robot with 95%+ rivets
Team 1501's Scorpion had 1900+ rivets
In the three years that we have been around we have probably used almost 5000 rivets.
Beat that, if you can
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 31-01-2008, 21:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Ribbit Rivet...
Ha! We've used over 10,000 rivets....
...all in the very same hole. Darn it, Eric, learn how to set those rivets already!
(Er, just kidding. We're up to maybe 50 or 60)
Don
Unread 26-02-2008, 22:01
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: Ribbit Rivet...
Rivets are quite godly indeed...
we use rivets wherever possible. Usually, we use the 3/16 variety for mid-high stress and then 1/8 for low stress applications. It saves quite a bit of weight compared to bolts.
We also got a very nice pneumatic riveter this year, which handles rivets VERY well, much better and faster than our old manual ones.
Personally, I find using rivets more convenient. Even if you need to remove them, it's usually not hard (just get a slightly undersize drill bit and pop it out). However, when the end of the rivet shaft dosent pop out right, then it's tricky to drill out without damaging the hole/piece.
Overall, though, I love rivets, and they're very likely why we're able to stay at weight. =D
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
pic: Lightning Robotics Pop Rivet logo Joe J. Extra Discussion 4 02-07-2006 19:18
