Go to Post The world is run by those who show up. - AdamHeard [more]
  #31   Spotlight this post!
Unread 11-11-2007, 21:57
AdamHeard's Avatar
Lead Mentor
Re: Cool Frame Ideas?
Originally Posted by JamesBrown View Post
Last year with 1493 we built a custom frame, the sides contained the transmission (a custom 2 speed based off the AndyMark shifter) and the wheels, the two sides were connected by 1 inch square tubing with 1 inch solid aluminum cubes welded on the ends. We threaded the cubes and connected the sides with counter sunk bolts. this allowed us to quickly remove one entire drive module and replace it with a spare. Allowing us to make repairs without having to miss matches of work directly around the robot.
I am going to attach a picture of the chassis, if you have any questions feel free to ask.
Just curious.... Why were the center wheels located more towards the centerline of the robot than the outer wheels?
  #32   Spotlight this post!
Unread 12-11-2007, 01:01
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Originally Posted by Qbranch View Post
Watch out!
We tried this stuff and it does look fantastic on paper, but they have a huge issue with being out of square. Well, not the connectors themselves, but what you put together with them. When we tapped our connectors in everything was nice and strong... but horribly out of square.
The robot frame we put together couldn't even hold an axle straight, let alone sit level. Maybe if you used force gauges or something when pressing the connectors in, or had really close tolerancs on the ID of the tube you use it would work... but just a heads up, with your ajax square tube it doesn't look too pretty...
-q
Thank you for the info--I too was hoping that by mentioning EZ Tube, somebody had to have seen it and tried it. Yes, I would imagine that in order to get a box frame that was square, you would have to have the opposite tubing pieces cut with 90 degree squared ends and be very accurate on the lengths since the lengths are controlled by the connectors bottoming out against the ends of the tubing. Keeping it squared up could probably be helped with some thin aluminum gusset strips and rivets, but now it's not so EZ.
Now that I've had time to look, the 80/20 system and the EZ Tube system look very similar, at least in concept, even with the availability of extruded tubing with panel-mounting flanges. EZ Tube connectors seem longer and have the option of the steel-core reinforcement (probably adds too much weight for a robot frame...probably).
Of course, if you're not worried about reusing the connectors, you could always use standard thin-wall 1" tubing and some two-part epoxy like JB Weld.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
  #33   Spotlight this post!
Unread 12-11-2007, 01:18
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Originally Posted by Hachiban VIII View Post
Get a piece of foam, carve it into the right shape. Add some spruce spars for extra structural suport. Cover it with fiber-glass or carbon-fiber, resin the whole thing and cover it with seran wrap to get it nice and smooth.
Then peil off the seran wrap an you'll have a nice smooth, strong, and earodynamic frame. And depending how well you squeeze out the excess resin - light too.
I've always wanted to build a robot that way. I <3 Fiber Glass
We may try some more composite work this year. Last year we learned how to do some basic layups and such, but it would be really cool to build an arm or more interesting mechanism out of carbon fiber rather than a square ramp, which rarely got used. Unlike what someone said, you don't need a large oven, you can build a simple one with just heat lamps. You just need to get the temp up to around 100 or so. Last year we turned a tool closet into a "hot box" to cure our ramps.
  #34   Spotlight this post!
Unread 12-11-2007, 01:39
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
In past three years, our team has welded together an aluminum frame (hot metal, flying sparks, random passerby blinded over the shield at 8:30pm, what's not to love?). Last year, we had it professionally done when we realized something was wrong with our MIG, and our team spent more time fixing it than actually welding. Usually the students weld... This type of frame is sturdy, bottom-heavy and we can always include our traditional 10-degree wedge, but can cause difficulties in adjusting or repairing the drive train. This year, we're going to try to design a frame that is just as sturdy but doesn't require extreme flexibility in the hands or a robot tipping to fix the drive train.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
  #35   Spotlight this post!
Unread 12-11-2007, 02:13
run the trap!!!
Team Role: Human Player
I don't know about these ovens you speak of.
Team 100 has used carbon fiber many times in the past. Usually we've just connected the pieces with resin and fiberglass.
-1995 We built our drivetrain out of a single piece of laminated carbon fiber with holes cut for wheels.
-2005 Our entire arm was made from honeycomb laminated carbon fiber that was resined together at the joints.
-2006 Our electronics board was made from honeycomb carbon fiber.
-2007 The v.2 "Head" (our manipulator) was made from a combination of wood and fiberglass with reinforced carbon fiber edges.
I'm personally not a big fan of the stuff. It takes special drill bits and saws to cut. And the edges are razor sharp, and can easily cut through wires and flesh !
But if you're still interested in using it check out your local Tap Plastics, or The Robot Market Place. I know in the past it has always been donated to us by Battlebots builders.
I tried to get a local bike shop to sponsor us last year and build our frame out of carbon fiber (using the same techniques they use to make custom bikes). But they were neither enthusiastic nor happy about spending thousands of dollars on us So it fell through...
-Philip J. Fry
  #36   Spotlight this post!
Unread 12-11-2007, 11:14
Doug G's Avatar
Coach / Teacher
-q
I was referring to what Qbranch mentioned...
1024 will eventually try experimenting with carbon fiber... as soon as we get someone to donate/get cheaply a large industrial oven.
-q
While in industry, autoclaves and ovens are often used, you can still get a good cure from building your own hot box.
-q
That's the kinda thing that would be interesting to make. Do you have any pictures?
  #37   Spotlight this post!
Unread 12-11-2007, 12:07
Rapt0r9's Avatar
Rapt0r9 Rapt0r9 is offline
AKA: Tyler
FRC #0747 (Flight Crew)
Rapt0r9 will become famous soon enoughRapt0r9 will become famous soon enough
Our team has just started to weld the KOP frame just last year. We were amazed at how much weight was saved when not using the steel bolts. Additionally, the frame was stiffer and we never had to sweep magnets across the floor to pick up the dropped hardware. (In previous years, we would lose at least 4 to 5 bolts each time we drove the robot. That was before we started using nylock nuts.) So for something that is cheap, quick and strong, just welding the aluminum frame if a great option. Also, you might want to considers using the U rails which have the extended bar (the one used for mounting the wheels) sideways and cutting off the excess aluminum which isn't giving any structural support. Here is a crude example of this.
Rotate this
*__
l__
**l
**l
To look like this
_ _
l **l___
(The asteriks are just there to space the lines out. My formatting is stripped each time I've tried to submit it.)
This has saved us a lot of weight over the past year.
We have considered using carbon fiber or fiber glass, but the big drawback to us is that repairing broken components is difficult. These materials can't just be welded or braced with another bar, we'd need to bring replacement parts and swap out the broken for the working. We've also found that pound for pound fiberglass is about as strong as aluminum, so we have never found a reason to switch.
BS Information Technology - NJIT (2009 - )
Team 869 (2004 - 2008, 2011 -), Team 1811 (2010), Team 869 (2009), Team 613 (2009 - 2010)
"Nothing in this life worth having comes easy."
  #38   Spotlight this post!
Unread 12-11-2007, 22:03
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
2004 and 2005 we built our robot out of HDPE. We found a local company that could weld the plastic. pictures http://team1322.org/pictures.htm
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
  #39   Spotlight this post!
Unread 13-11-2007, 11:50
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Wow, thats a cool idea! Did you have much of an improvement in weight reduction? Any problems with warping? Unexpected benefits? Detriments? Why did you stop using HDPE in your machines?
I remember making our 2006 robot's auto-retracking guides (in case the robot tried to throw a track) out of UHMW and had a heck of a time doing it... i think i spent more time whittling with an exacto knife than actually machining the parts.
Very interesting...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #40   Spotlight this post!
Unread 13-11-2007, 12:07
joeweber's Avatar
Coach team 1322
No savings in weight, but this was before bumpers, was very srong but did flex, I think thats what made it strong. The big benifits was that the students could work on the material with out hurting themselves. It was like working with wood with out the splinters. When you run a wood screw into it it held very well. The weld are just as strong as the material. We have not useded it because of the design of the robots would not make it feasable.
  #41   Spotlight this post!
Unread 13-11-2007, 13:24
Back after 4 years off
FRC #5279
If I Recall it was just an ease of mounting decision. We wanted wide wheels in the center to push but didn't want to have to make the whole drive module wider.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
  #42   Spotlight this post!
Unread 13-11-2007, 15:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by DeepWater View Post
Madison et al.
As far as using the connectors with standard 1" thin walled square tubing I really don't think it will work. The 1" square 80/20 QuickFrame tubing is specially fitted for the connectors. It has longitudinal ribbing inside that forms a friction lock with the plastic connectors. This is sort of the secret to the whole system. The internal dimensions of the QuickFrame tubing is slightly smaller (thicker walled than standard 1" thin wall box tubing) so if you try to insert a QuickFrame connector into standard 1" thin walled box tubing the connector will just fall out (too loose). The tubing isn't really that expensive though. IIRC the standard 1" QuickFrame box tubing was about $10-$11 per 12 foot (145") piece after the discount. They also have tubing with flanges on the side in different arrangements for putting panels in, etc. We purchased some but didn't really use the flanges much and often just cut them off to save weight.
One trick we found was to drill a hole in the end of the tube through into the connector and put a pop rivet in on any connectors you REALLY don't want to back out. This trick is rarely needed but is cheap (and light) insurance.
Ah, thanks. I was pretty well assuming we'd need to drill through the connector and bolt it since I don't trust anything that's meant to be a press fit, so maybe that would be enough to hold even a loose nylon connector in place. I'll order a handful and see how it goes, I guess, but I can't see going through the time or expense of ordering new metal stock; especially if it's already anodized and harder to work. Even with a bolt through each, it seems like this will be as light or lighter than our existing methods of joining tubes -- lots of rivets and joining plates. The really nice thing about these is that they'll save lots and lots of manufacturing time, we hope.
--Madison--
...down at the Ozdust!
  #43   Spotlight this post!
Unread 13-11-2007, 18:14
run the trap!!!
Search before you post I got this picture off of your own team's website!
-Philip J. Fry
  #44   Spotlight this post!
Unread 14-11-2007, 23:40
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
side panels:
1" thick lightweight aluminum honeycomb, laminated to high density carbon fiber composite sheets on either side of the honeycomb.
internal frame: some 1x1x1/16" box beams to keep the side panels from crushing inwards.
analysis on such honeycomb and carbon fiber side panels show that the central layers of honeycomb take next to no force, and all the force is taken by the outside edge. so make it out of carbon fiber. superlightweight, and its strength increases exponentially the thicker the honeycomb layer is. then just make up a simple frame to keep the side panels in place, and cover the carbon fiber with like 1/2" foam to keep it from cracking under high pressure impacts. and then you have a really strong, lightweight frame.
my research group is using stuff like this... its lots of fun. the stuff weighs as much as foam and is as rigid as a steel plate.
the frame kaboose Technical Discussion 7 11-01-2007 22:38
Riveting up a frame Billfred Technical Discussion 27 19-12-2006 19:49
Cool new ideas for FIRST Robots - who has them? sanddrag General Forum 44 04-08-2005 15:02
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Frame connections manleycor Technical Discussion 15 18-11-2003 01:14
