Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 13-11-2007, 18:26
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
VEX Challenge Scorekeeper
I am trying to get this program running, I have the scoring server up, also I have the Audience Display Running on my extended monitor. The Challenge Scorekeeper is work as far as uploading the teams and creating the matches. But when I start the Match, the automations 20 seconds run then when it turn 2:00 a windows ask me to contine out of the automations part. I click ok then the robots don't move. No matter the port I plug into it does not move. Have anyone had this problem. The bot is on and so is the Controller, can anyone help me out?
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 13-11-2007, 20:00
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
Re: VEX Challenge Scorekeeper
1st question, are you using EasyC or MPLab to program the robots?
2nd question, are you using the 2007 Competition template?
3rd question, have you updated the master code on the controllers to version 7?
If it's EasyC make sure that you have no jumpers in interrrupt 5 and 6 on the controller.
Hook the robot up to the computer and start the terminal in Easy C. You should see 3 things:
1) The Master code version. Make sure it is v7
2) Then something like "Autonomous (20)"
3) after 20 seconds, you'll see something like "Operator Control (254)"
If you see all those, then the robots have the correct pieces they need to operate with the field controls.
The controllers are very simple and only enable/inhibit radio transmissions. In practice I have yet to see them behave incorrectly by not enabling robots when the scoring system tells them to. We ran a number of matches at the FTC scrimmage at Ramp Riot without any issues.
Also, try unplugging the transmitters from the field controls and see if the robot really is operating correctly.
Hope this helps.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 14-11-2007, 00:20
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
Hope this helps.
We are hosting the Arizona Regional, I am not programming robots at this time. I am using the Scorekeeper, the Audience Display, the game sever, as well as the pit display. If anyone has hosted a regional before and ran the scoring software, you know what am talking about. Although I do not know anything about the jumpers need to play the autonomous parts. Thank you!
Team 842 Programmer
Pictures at:
Videos -
Unread 14-11-2007, 06:44
It's still worth checking if the robots you are testing with are programmed correctly. The correct master code and template are required for the robots to work correctly with the field controls.
When the scoring software goes to the operator controlled portion of the match, try unplugging the controllers from the filed control. If the robots begin to work you may have a flaky field control and may need to contact IFI.
You may also want to switch out the cables that tether the transmitter to the field controls. We've seen the cables cause issues occasionally.
I've run the field at 2 scrimmages with no problems, so I know the scoring system software works correctly with the field controls.
Unread 15-11-2007, 19:45
kE7JLM's Avatar
KE7JLM `
AKA: John Harris
Team Role: Driver
I got the robots to work when I press this start button, but there is still a problem. The autonomous mode does not run the first 20 seconds! The robots just don't move (as if there was no autonomous code) there are still tele-operated.
On a side note, why is there a "VEX Arena Controller"? and the Scorekeeper?
Which do I use?
Team 842 Programmer
Pictures at:
Videos -
Unread 16-11-2007, 06:57
Can the robots be operated before you press start? And do they become disabled when the autonomous timer expires (and again at the end of the match)?
I know I may sound like a broken record, but it sounds like the programs were started using the 2007 FTC Competition template. The template and the master code are what determine if the robot is in autonomous mode or operator controlled mode. The field controls only enable or disable the transmitter.
Also make sure the start up sequence is correct. Make sure both the robot and transmitter are OFF. Put the robot on the field. Plug the transmitter into the field controller. Turn on the robot. Then Turn on the transmitter.
Which do I use?
The "Vex Arena Controller" is a generic tool to operate the field controllers that is supplied by Innovation FIRST with the field controls. You can use it for testing or if you were running an event where you want to change the timing.
The scorekeeper software is an integrated solution developed for FIRST that handles all aspects of scoring (match generation, displays, rankings, alliance selection, individual match scoring, and robot control). That is the one you should be using.
2006 WIRED Vex Challenge and Milwaukee Vex League Kevin Kolodziej Off-Season Events 15 04-12-2006 09:59
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
FRC/VEX Challenge Rick TYler General Forum 32 05-04-2006 21:54
2005 Vex Challenge FIRSTgurl93 FIRST Tech Challenge 0 11-11-2005 13:16
Biggest challenge in VEX Keith Chester FIRST Tech Challenge 4 06-06-2005 20:55
