Go to Post It made me proud to know that we have corporate sponsors with genuine interest. - galewind [more]
Unread 14-11-2007, 06:44
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
Re: VEX Challenge Scorekeeper
It's still worth checking if the robots you are testing with are programmed correctly. The correct master code and template are required for the robots to work correctly with the field controls.
When the scoring software goes to the operator controlled portion of the match, try unplugging the controllers from the filed control. If the robots begin to work you may have a flaky field control and may need to contact IFI.
You may also want to switch out the cables that tether the transmitter to the field controls. We've seen the cables cause issues occasionally.
I've run the field at 2 scrimmages with no problems, so I know the scoring system software works correctly with the field controls.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
2006 WIRED Vex Challenge and Milwaukee Vex League Kevin Kolodziej Off-Season Events 15 04-12-2006 09:59
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
FRC/VEX Challenge Rick TYler General Forum 32 05-04-2006 21:54
2005 Vex Challenge FIRSTgurl93 FIRST Tech Challenge 0 11-11-2005 13:16
Biggest challenge in VEX Keith Chester FIRST Tech Challenge 4 06-06-2005 20:55
