Go to Post Haha, I applaud your efforts to read into the actions of the GDC, but I feel like trying to do so is like shooting at a target, in the dark, at a mile away, with a sawed off shotgun. - ttldomination [more]
Unread 14-11-2007, 13:18
jimmyrock88 jimmyrock88 is offline
jimmyrock88 is an unknown quantity at this point
Mplink error
hey guys i m gettin this link error:
MPLINK 4.11, Linker
Copyright (c) 2007 Microchip Technology Inc.
Error - section '.code_vfprintf.o' can not fit the section. Section '.code_vfprintf.o' length=0x00000c22
Errors : 1
I would guess its because MPLAB doesn't alloy more than 256 bytes ( which is default)
I have also seclected the option "Large Code Model >64Kbytes" and "Large Data Model" from Project->Build Options ->Project.
You think that the chip doesn't have enough memory. Should I change it to PIC184431 (has more memory) from original PIC184331 ?
Here's map file.
Unread 14-11-2007, 15:42
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Mplink error
If you are using a large array try doing
rom unsigned int array[256];
putting rom in front will put the variable in the program memory which has a log more space
Unread 14-11-2007, 15:50
Re: Mplink error
rom won't help this, the controller doesn't have enough program memory to hold all the code you're trying to shove into it.
The code needs to be trimmed down or you need a processor with more memory.
You can get a very rough idea of how much more didn't get into the space allotted by looking at the Linker command and seeing where printf.o probably fell and what is listed after it.
You could also, as you seem to suggest, select a target PIC that has a lot of memory, then take a look at the MPLAB memory gauge to see how much space it all takes up.
Are you compiling with a particular PIC in mind or don't you care which one is the target?
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
MPLink Error cloudago Programming 2 01-02-2005 23:00
