Go to Post P.S. While I doubt Karthik's "Delgado" jersey would go for $500,000... it would be much cooler to see Carlos Degado wearing a "Kanagasabapathy" jersey. THAT I might pay for! - dtengineering [more]
Unread 20-11-2007, 19:50
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
top hat
the little button for relays on the top of the controller... in between the aux 1 and aux 2 buttons.
what is it called in code please.??
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
Unread 20-11-2007, 20:22
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: top hat
its actually an analog input. im not sure of the exact syntax but its the wheel axis. each direction outputs a number approximately 50? apart. sorry but i dont know the numbers off of the top of my head.
hope that helps
...Forest
EDIT: are you talking about the hat switch on the joystick? or something else because that ^^^ is for the hat switch
Unread 20-11-2007, 20:43
Re: top hat
It connects various resistors from +5 Aux to the same pin as the throttle wheel on a classic CF joystick. The code reads it as p#_wheel (where # is one of 1 through 4).
Unread 20-11-2007, 21:24
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: top hat
Reading it is kind of weird. At least for mine:
pX_wheel (X is 1 to 4, as Alan said)
Neutral   : 47
Left      : 97
Left Down : 163
Down      : 149
Right Down: 212
Right     : 201
Right Up  : 253
Up        : 253
Left Up   : 253
So unless you reeeaally want the bottom left and right... You can subtract 60, divide by 50, and cut off the decimal. That'll make neutral 0, left 1, down 2, right 3 , and up 4.
Those were for the one sitting next to me, I have no idea of they stay constant between joysticks. But subtracting 60 should be enough to get it all. =)
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Rack'n'Roll Hat 1359th Scalawag General Forum 9 15-04-2007 17:57
"Cool" Hat or Punk Hat? Eugenia Gabrielov Chit-Chat 17 02-03-2005 21:59
Joystick Hat button ten3brousone Programming 8 20-02-2005 13:31
Jostick HAT stick krhs_programmer Programming 2 06-02-2005 18:26
