Go to Post The most important things for a team to take to any competition are a sense of humor, a big bottle of Advil, and a camera! - Rick TYler [more]
View Poll Results: Is it bad to shutdown a computer by using the Power Button
Yes 24 55.81%
No 15 34.88%
Undecide 4 9.30%
Voters: 43. You may not vote on this poll
Unread 20-11-2007, 15:04
whlspacedude's Avatar
whlspacedude whlspacedude is offline
AKA: Will
FRC #1529 (Cyber Cards)
whlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nicewhlspacedude is just really nice
Send a message via AIM to whlspacedude Send a message via MSN to whlspacedude Send a message via Yahoo to whlspacedude
Computer Shutdown
Just wondering if it is bad for a computer to be shutdown by pushing the power
button.
I had always assumed that the power button served as a shortcut for shutting down windows. But my PLTW teacher does not seem to think so.
Some people are like slinkies they are only good for 1 thing... pushing them down flights of stairs
1529 mph = 4 109 952 furlongs per fortnight
Unread 20-11-2007, 15:53
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Computer Shutdown
I always thought of the power button as an emergency shutdown only button, but seeing as it only takes about a minute more, why not just cut the possibility of computer problems and shut down the computer the normal way.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 20-11-2007, 15:57
I only use it to shut down if the computer completely locks up. Then I start the computer back up so I can shut it down properly.
Unread 20-11-2007, 16:44
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
What exactly do you mean? Pressing and holding the power button to turn off your computer is always a bad thing unless you absolutely need to. However, since Windows XP came out (and maybe 2000, but definitely not 98) pressing, not holding, the power button will trigger sleep, hibernation, shutdown, or nothing at all depending on your power settings. If you set the power button to trigger a normal shutdown when pressed, then there is no problem with pressing it as long as you do not hold. Just don't try it on older computers, such as Windows 98 and previous version computers, because most of their power buttons literally are power buttons (immediate shutdown).
So yes, the power button may be a shortcut in modern computers for shutdown. From my experience, some modern computers actually have the power button set to sleep by default instead of shutdown.
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
Unread 20-11-2007, 16:48
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Edit: beaten by the above post
Well, on ATX motherboards if you just press the power button once Windows will shut down normally (or stand by, or hibernate, depending on your power settings). That's ok.
But if you're talking about holding down the power button until the computer abruptly shuts off, then yes, it can be a bad thing. If the computer was in the middle of a hard disk write, you can end up with corrupted files. For example, I spent the better part of Thursday at the 2006 Championship fixing the only laptop that had our (296's) code on it, because someone had shut it down incorrectly and it couldn't boot Windows because of corrupted system files (it only took that long to fix because it had some kind of funky SATA-RAID system that required 3rd-party drivers).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 20-11-2007, 17:06
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I agree with alll the above posts. It's only a good thing when you have your computer already locked up.
Also, most people don't safely remove USB type devices as well.
I don't think removing something like a USB printer, or a USB powered toy-like device (fan, christmas tree, cup warmer) is going to kill anything, but that USB connected jump drive, or portable hard drive could in fact be corrupted in the same way if you don't use the "safely remove hardware" icon in your task bar.
Although, my experiences with a USB external HD is one of sheer luck it seems sometimes.
Sometimes it says it's cool to remove the first time I click that, and other times it yells at me and says it's not cool to remove hardware even though every window is closed that I had open that was referencing that drive.
In that case, I hit the button to shut it off if no lights are on the external hard drive itself, and have been so far (knock on wood) good to go the next time I have started it up.
Unread 20-11-2007, 17:34
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
At my school, they always tell the students to shutdown properly, the only problem is that even the techs use the power button to shut down. If your computer has the capabilities to shut down when pressing the power button once, then I say go for it. It is very hard on the computer if you press and hold the button however.
I win! XD
Unread 20-11-2007, 17:43
DonRotolo's Avatar
Back to humble
FRC #0832
Depends on your OS
By cutting power, your Windows machine may be in an undesireable state at that moment, for example writing a file (even if you don't know it), and you can cause it harm. In newer machines, where you ahve to hold the power button for it to shut down, the CPU knows enough to abort all operations, so there is a reduced chance of problems, but that is very far from zero.
On the other hand, that's the only way to shut down a computer running DOS.
Don
Unread 20-11-2007, 18:10
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
It depends. If you push the power button it will many times "safely" shut down your computer. If you keep it pressed though it will "unsafely" black out. The first one for the lazy people that are in a hurry yet still want to save money on power and the latter for those whose computers have frozen and have work to do!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 20-11-2007, 18:51
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
The big problem is if you are in the middle of a file write. You can get bytes in weird places..
This is usually what happens if you aren't careful when you unplug your flashdrive. For computers, it's not really a huge issue. If I'm in a rush, power button. Else, shutdown normally.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 21-11-2007, 00:18
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I put undecided.
I am fully aware of the DANGERS of unsafely turning off your computer, but...
I have on numerous occasions (ok maybe daily) turned off my computer forcefully, without a problem (to my knowledge.) Just make sure your computer isn't 'busy' or reading/writing to the disk. As long as everything is safely written to the disk, and the head is off the surface, I can't see anything bad going on (some corrupted temporary data... big deal?)
So my IT Admin self says 'NEVER turn it of improperly', but my gut says 'Just make sure the disk isn't writing.'
Jacob
Unread 21-11-2007, 06:48
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Originally Posted by whytheheckme View Post
I put undecided.
Jacob
you it is right, when you shutoff (HOLDING the power button, not just pressing it) that way sometimes there is a small surge, not enough to actually damage anything, but the more you do it the more life you take off your processor...
i have to explain to everyone that processors are like trucks... a 2.4 ghz isnt going to put out 2.4 ghz forever
Unread 21-11-2007, 07:59
I agree with Don above...only as a last resort when you are sure there is no coming back. Unfortunately, there are frequently times when you have asked Windows to do too much in addition to it's own housekeeping. It may looked locked but in reality it is too busy doing what it needs to do to even listen to you. Pressing the keyboard or moving the mouse appears to do nothing but in reality the computer is storing that input(s) until it can service them. On older machines (In the ancient past circa 1990) you would never press the power button to shut down unless you had control of the system. A power down in the days before protected drives meant a head crash.
Unread 21-11-2007, 09:53
AKA: Will
For Clarification:
Yes, this is what i mean.
Unread 14-01-2008, 15:42
MTGdiablo MTGdiablo is offline
AKA: CHOMP CHOMP CHOMP CHOMP CHOMP CHOMP
FRC #1529 (CyberCards)
MTGdiablo is an unknown quantity at this point
Send a message via AIM to MTGdiablo
I selected yes, because I have actually gotten the "blue screen" because of pressing it to shut it down in emergencies.
My computer used to lock up all the time (because I accidentally had a magnet on the cpu that I couldn't see >.<), so I would constantly have to press and hold it to turn it off, causing the "blue screen", which is an internal/harddrive error.
So all in all, I believe that is is a horrible thing to do, pressing and holding the power button to turn off your computer.
Like tawnos23 said, just give it an extra minute.
CHOMP CHOMP CHOMP
C:\Documents and Settings\346871\My Documents\My Pictures\SOAD.png
Offline computer? Calvin Programming 2 19-01-2006 14:22
Computer Stupidity sanddrag Chit-Chat 1 10-07-2005 17:50
Startup/Shutdown sounds Jeff Rodriguez Chit-Chat 4 06-06-2004 22:42
My computer is nuts LBK Rules Chit-Chat 6 28-01-2003 19:43
Computer control maDGag Programming 1 27-12-2002 01:13
