Go to Post I would contend that you cannot have a consistently good robot without equally good teambuilding. - jonathan lall [more]
Unread 22-11-2007, 13:54
donmillsci donmillsci is offline
FTC #0473
donmillsci is an unknown quantity at this point
Re: pic: Team Unlimited's Gear Shifter
Just a few questions about your gearbox and chassis design:
  • Is there a tendency for the gears to get stuck while switching gears in motion?
  • While it's stationary?
  • Are there ever issues with the chains on the sides falling off or becoming jammed? (Especially if hit by objects, like the rings or other robots.)
  • What is the purpose of the omni-wheels? It looks like they are suspended in mid-air and aren't actually used to support or drive the robot.
  • Is it necessary to have 2 motors per side?
Unread 26-11-2007, 14:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Since it's not single-design oriented, I believe I can answer the motors per side question.
Certain teams might not find it necessary to have 2 drive motors per side. However when you weigh the entire robot down with steel manipulator parts, if you're geared for speed you'll definitely notice lackluster power due to the extra mass. In other words it will take (seemingly) forever for the bot to get up to speed.
If you have a very lightweight bot or it's only geared for med-high torque situations (therefore low speed) you could probably get away with 1 motor per side.
GitHub
pic: FVC 2013 Gear shifter gdo Extra Discussion 16 27-04-2007 14:25
pic: 1732's 2 servo shifter John Wanninger Extra Discussion 1 04-03-2007 23:27
pic: Team 948 2 speed dog shifter adlai Extra Discussion 3 05-12-2006 07:54
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
pic: AM shifter mount close up falconmaster Extra Discussion 2 18-01-2006 19:27
