Go to Post Givens do not need solutions. - Al Skierkiewicz [more]
Unread 23-11-2007, 19:21
ruddy ruddy is offline
FRC #1261
ruddy is a splendid one to beholdruddy is a splendid one to beholdruddy is a splendid one to beholdruddy is a splendid one to beholdruddy is a splendid one to beholdruddy is a splendid one to behold
TTL CMUcam2 2004 eduRC bug... HALP PLZ
Basically I'm using the 2004 edu RC, and I'm trying to get the camera working. I plugged in everything (to the best of my knowledge), and nothing really happens except it turns on and the camera goes to its default position. When I upload the code, the camera doesn't even search. I think I narrowed the situation down to the TTL not working, but would that prevent the camera from going into "search" mode? Also, can someone help me configure the TTL adapter... I'm drawing .5v from one of the PWMs into the spare slot on the TTL adapter. Thanks in advance guys
Unread 23-11-2007, 21:04
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: TTL CMUcam2 2004 eduRC bug... HALP PLZ
Yes, if the camera is not present(It won't be if the TTL adapter is faulty) there will be no tracking information, and initialization will fail so no searching will take place.
First I would download the 2007 CMUcam2 Setup and Initialization PDF and see page 5 for the TTL port pin outs. Looking at it they are left to right GND, TX out, +5V, Rx in with Rx in being closest to the 9-pin connector.
It should be wired it as follows:
+5V from one of the PWM's to +5V on the Camera TTL port
GND from the EDU TTL to GND on the Camera TTL port
TX out from the EDU TTL to RX in on the Camera TTL port
RX in from the EDU TTL to TX out on the Camera TTL port
*Yes you need to cross over TX and RX pins*
*You will not need a TTL to RS-232 adapter*
*This will both power the Camera and allow for data transfer*
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 23-11-2007, 21:33
FRC #1261
i love you man.
Unread 21-12-2007, 22:26
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
I am sure that the above works fine, and is probably better in the long run than the following. If you don't want to ruin a PWM cable or perform any sort of "hack" on the thing, plug stuff in as follows:
You will need:
•4 PWM cables. 3 pin each, male-female.
•1 TTL-RS-232 adapter (comes with CMUcam)
•Free TTL Port
•2-4 other free PWM ports on EduRC
What to do:
•Connect a PWM cable from the TTL port on the EduRC to the closest 3 of the 4 sockets on the TTL adapter towards the RS-232 out pins. (just follow Black to Black)
•Connect the black socket of one PWM cable to the middle pin (+5v) of a free digital in/out PWM on the 2004 eduRC. Yes, you have to plug it in sideways. I suggest taking up 2-3 ports so that the cable doesn't fall out.
•Connect the respective pin of that cable to the free socket on your TTL adapter (towards the edge, NOT the B. Again, you WILL have loose pins floating out in space.)
•Connect a PWM from the RS-232 out on the TTL Adapter to the RS-232 PWM in on the CmuCam2 board. Plug Black into B as always.
•For power, connect the last PWM cable from another free PWM socket on the EduRC to the cmucam. (to the port near the power switch).
Works for me. (and I didn't even have to risk loosing a PWM cable!)
TTL Issues Bomberofdoom Programming 4 31-01-2007 09:23
2004 Edubot Serial String Help (TTL in) Josh Siegel Programming 6 10-12-2006 08:28
TTL Ports bludstayne Programming 3 02-03-2004 16:41
TTL pins Dave... Control System 3 07-02-2004 23:59
how do i tell to the edurc when the remote is on. Code\\Pilot Programming 4 28-01-2004 21:00
