pic: Team Unlimited's Gear Shifter
Re: pic: Team Unlimited's Gear Shifter
What sensors are you using in the back of your robot?
Pretty sure they are using optical shaft encoders to detect axle rotation.
how much vex do you guys have!?!?
That's what I thought, just wondering if it had anything to do with stopping the motor that changes the gears.
I think it would be best to use a real servo with a limited rotation and exact position for shifting the gear, instead of a motor...
all in all amazing design! very cool! I really like how it shows the complex notion of gear changing in an easy to understand way... -Leav |
#7
How did you guys get those three gears in the back flush against each other (cut off protruding edge or just different gears?)
#8
You got it, they would have had to grind down the edge.
#9
isnt that illegal
#11
that is cool,but do you guys have a problem with the gears grinding as you shift. or do you stop,then shift. Just wondering?
#12
There design is shift on the fly but the can shift stationary. The rack and pinion make much it smoother. I dont know if you can see it or not they also beveled the gears with a drill and sandpaper.
#13
o yea i see that now thanks.
| pic: Team Unlimited's Gear Shifter | gdo | Extra Discussion | 2 | 26-11-2007 14:50 |
| pic: FVC 2013 Gear shifter | gdo | Extra Discussion | 16 | 27-04-2007 14:25 |
| pic: 1732's 2 servo shifter | John Wanninger | Extra Discussion | 1 | 04-03-2007 23:27 |
| pic: Team 948 2 speed dog shifter | adlai | Extra Discussion | 3 | 05-12-2006 07:54 |
| pic: team 1029 shifter | bjimster1 | Robot Showcase | 4 | 21-02-2006 10:23 |
