Go to Post FIRST builds bridges, and absolutely should not build walls. - Jacob Bendicksen [more]
Unread 24-11-2007, 18:39
BlackShadowFox's Avatar
BlackShadowFox BlackShadowFox is offline
AKA: Madwolvez
FRC #0401
Team Role: Electrical
BlackShadowFox has a spectacular aura aboutBlackShadowFox has a spectacular aura about
Send a message via AIM to BlackShadowFox
"DIN rail" or Not
Well this has been bothering me for a while now. As like many of you we all don't enjoy the new power distribution block for it being big and heavy and not making much sense in our application at certain "POINTS" like when using one atc fuses panel. But anyhow to the question in mind is:
Is there any rules on how to mount the power distribution block?
Such as do we need the DIN rail or could we make our own way?
For people who are confuse about what I'm talking about it is quite simple, i would like to mount the power distribution block in pieces (like black and red) sideways using a different mounting method.
So can you find any problem with this simple mounting change?
Also if you look in the 2007 wiring diagram the 2 atc fuse panels are wired on separate positive wires from the distribution block as for the negative uses one wire why from the PDB. I know ground is common but this wiring diagram is misleading. anyhow don't get cared away on this last part but focus on the mounting topic.
Curiosity killed the cat, satisfaction brought it back.
Congratulations is spelled with a "T" and not a "D"!! Elgin Clock Thanks and/or Congrats 55 09-03-2007 13:24
Purchasing DIN Rail Parts Bio Electrical 0 01-02-2007 18:48
DIN Rail? cdennisxlx2 Inventor 1 19-01-2007 07:51
Exempli Gratia: "Jason Morrella" not "Jason Morella" Bill Gold CD Forum Support 8 10-10-2004 19:01
Bug: "Infinite" Login not "Infinite" Ian W. CD Forum Support 15 08-12-2003 10:32
