Go to Post We all need to keep things in perspective. When you look back at the entire 2005 FIRST season, is your entire experience defined by the presence of a little cloth flag on the play field? - dlavery [more]
Unread 25-11-2007, 11:29
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: pic: Kitbot Chain Tensioner 2
Originally Posted by richardmcc2 View Post
Just out of curiosity, where did you get those gears for the encoder setup you have? And how is the lower gear on the 1/2" Banebots shaft attached? Is it a set screw? Did it come with that 1/2" bore or did you have to enlarge it?
Those are 36 tooth, nylon, spur gears that we ordered from McMaster-Carr (pg 1012). The come stock with a 1/4" bore, which is great for the encoders, but had to bore them out to 1/2" for the banebots and add a 1/8" keyway using a broach.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
