Go to Post Our robotics lab has been closed for two days, TWO DAYS! :ahh: - Kevin Selavko [more]
Unread 27-11-2007, 15:11
in between teams
AKA: Luke Van Oort
Re: robot speed
I don't think planning a speed now will get you a head start. Unless you are mounting your wheels directly on the transmission output shaft (West Coast Drive style), it is really easy to change speeds; all you need to do is swap sprockets.
Team 1219: 2009 - Mentor
Unread 27-11-2007, 15:22
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: robot speed
OK, I'll say it .......
IMHO, a top speed of 10-12 fps is a good place to start if your kicking around ideas about generic robot designs. A robot that can do this will be somewhere in the high middle of the pac as far as it's ability to beat a competitor from point A to point B on the playing field. Chances are that if there's any serious pushing to be done, you'll need to add a two speed gearbox to your design to get the torque back.
Ed Sparks
MECH TECH FRC-3959
Unread 27-11-2007, 17:26
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: robot speed
the kitbot sprocket setup last year came to about 15 feet per second. it was really fast and we mostly blocked with our sides since we had a caster drive (the front had casters and the back two wheels were the drive wheels)
"we don't build robots, we build people"
Unread 27-11-2007, 18:51
in between teams
AKA: Luke Van Oort
Re: robot speed
I don't know where that number came from; the kit drive system last year was geared to a maximum speed of 7.24 ft/s. Of course, that is just a theoretical top speed that doesn't take into account drive system inefficiencies, and the actual top speed is probably somewhere in the fives.
Unread 27-11-2007, 22:38
vivek16's Avatar
AKA: vivek
Re: robot speed
umm... well our way of measuring it consisted of this: having a team member(in cross country) run down a narrow hallway of 20 feet long at the speed at which we thought the robot went at. and then timing
rookie tip: whatever you do, be more prepared than we were..
Unread 28-11-2007, 03:16
AdamHeard's Avatar
Lead Mentor
Re: robot speed
Why not have the robot do it instead?
Unread 28-11-2007, 06:04
vivek16's Avatar
AKA: vivek
Re: robot speed
well the pit crew was trying to make it work
I was with the programmer because he needed the speeds for autonomous mode: ours consisted of driving across the field and waiting to defend against other robots.
-vivek
Unread 28-11-2007, 07:12
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: robot speed
Originally Posted by cloud_254 View Post
good point but, i'm just trying to guess for this year's competition. i know kick off isn't til jan 5th but i'm just trying to get a head start.
The best head start you can have is to get to know the tools and develop the skills that will help you do it quickly and efficiently once you get all of the information at kickoff.
Rule of thumb in picking a ratio... let the kitbot be your guide. If you want to be fast, be faster than the kitbot. If you want to be a pusher push harder than the kitbot. So for now, just plan on one reduction that you can easily change to hit any of the speeds discussed.
Mark
Brick walls are for other people. - Randy Pausch
Unread 28-11-2007, 19:48
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
Re: robot speed
Originally Posted by Richard View Post
Since alex1699's school in located in the middle of Connecticut, I doubt that his team is actually a bunch of rednecks. More likely it is a bunch of yankees.
I, on the other hand, attended a public high school in the middle of South Carolina. My school was quite literally full of rednecks. Some (most?) of my best friends were rednecks. (And the rest were transplanted yankees!) Rednecks are known for many quirks that non-rednecks might find strange, but a preference for slow gear ratios is emphatically NOT one of them.
Conclusion: Adam is right, the point is ambiguous at best.
ok im sorry but we are rednecks we all have 4 wheel drive suvs and go muddin and then also rid cheap plastic quads down snow bank hills and we made are robot is a two car grudge listen to country and are town is a small town with onle about 900 kids in ar school. and then some how we got a bike stuck 3 to 4 feet feet deep in mud...... i dont no what you think red necks are but for team in the middle of Connecticut i think we are pretty "red neck".
o yes i do stink a spelling so dont correct me please....
Curie..
Unread 28-11-2007, 20:08
alex1699's Avatar
Re: robot speed
and im not talking down my team we all love it and are have amazing fun and redneck is not a bad thing
Curie..
Unread 28-11-2007, 20:34
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: robot speed
Well, I just learned something. Connecticut rednecks! Who knew? My apologies.
Richard Wallace
since 2003
Unread 29-11-2007, 12:17
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: robot speed
To stay on topic --
The whole speed vs. control is greatly recognised in an FTC match. Many students, when left to themselves, design their drive trains separate from the rest of the robot. So maybe they design the bots to use the large wheels with a 1:1 ratio or tiny wheels with only 1 motor per side. Then they add all of the mass of the steel and nuts and bolts above their drive train and get very lackluster performance out of it.
This is why I think that if you must go single-speed, 10fps is a good speed to aim for in FRC. Smaller wheels give you slower speed but more torque by design, and combined with a medium gear ratio will allow for decent accleration with only 1 motor per side after you've added all of the weight above it. If you make it 2 motors per side, you might even win some pushing matches.
2017 Scoring Model
CAD Library | GitHub
Unread 29-11-2007, 19:46
alex1699's Avatar
Re: robot speed
sorry about that all with the redneck thing a friend did it i didnt sorry...
Curie..
Unread 30-11-2007, 16:17
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: robot speed
Perhaps either you or your "friend" should start using punctutaion and capitalization. Right now your typing is remarkably similar.
Unread 01-12-2007, 05:42
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: robot speed
Winnovation had a 4 wheeled 3 speed shift-on-the-fly coaxial swerve drive and that was great for awesome defense and good scoring capability, very controllable as well when it wasn't freaking out.
Speed of the robot FRC1710 Control System 6 15-01-2007 16:10
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 11-03-2004 21:39
Maximum Speed of a Moving Robot Part UlTiMaTeP General Forum 1 12-01-2004 05:57
Final Robot Speed kacz100 General Forum 8 03-02-2002 16:47
Robot Speed schitnis General Forum 4 20-01-2002 05:32
