Go to Post Mastering simple skills can be a complex challenge. - Petey [more]
Unread 28-11-2007, 19:02
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Best source for a potentiometer?
I have heard to avoid radio shack. Digikey is used often. and they have a cool selection process.
"we don't build robots, we build people"
Unread 28-11-2007, 19:09
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
I'd also say to avoid Radio Shack. I purchased a potentiometer there for our robot last yearand I could only use about half of the rotation because it would give the same value close to the extremes of rotation.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 28-11-2007, 20:49
You might have accidentally purchased a "log taper" or "audio taper" potentiometer. For position sensing, a "linear taper" pot is preferred.
Unread 28-11-2007, 22:02
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Two solutions. Either a 10 turn pot if you want or you can couple two continuous pots to cover all 0-259 degrees. I'll get part numbers for ya tomorrow.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 28-11-2007, 22:23
Gdeaver Gdeaver is offline
FRC #1640
The Ametes absolute position sensor is ideal for arm position. It would have to be mounted on the joint. If the arm joint design does not permit mounting on the joint, It could still be used with some additional programming.
Unread 28-11-2007, 22:24
RyanN's Avatar
RyanN
I ended up ordering this potentiometer:
http://webtronics.stores.yahoo.net/73jb50k.html
Hopefully it will arrive soon and work well.
Controls Mentor
@rnazaretian
Previous teams:
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Open Source CAD Jeff Waegelin Inventor 5 16-12-2004 12:51
[FVG]: Source Code SilverStar FIRST-related Organizations 5 24-08-2004 14:28
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Virtual Match Viewer SilverStar Programming 6 19-04-2004 16:19
