Go to Post We'll get through this as a community, this we know. - JaneYoung [more]
Unread 30-11-2007, 18:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Position idlers to get better chain wrap -- a question about good practices.
Bicycle idler sprockets routinely have a serpentine chain wrap--more than you seem to want.
true, but they cheat and make sure there is very little chain tension on the part of the chain with the derailleur (the part with all that wrap). The loaded (top) part of the chain is a straight shot from crank sprocket to wheel hub sprocket.
One thing we learned in 2006 is that if you use the "elegant" solution of making the axle moveable to adjust chain tension, that you really do need to make it elegant, not just a bolt thru a slot.
One thing we learned in 2007 is that the idlers/tensioners need to be part of the initial design concept, it's not easy to just add them in later and have it all work out.
In other words, I don't have an easy answer for Madison!
Computer good practices vivek16 IT / Communications 25 21-11-2007 10:50
pic: A Better View of Racky With All Cylinders in Stowed Position DanDon Robot Showcase 2 20-02-2007 21:06
Rules about pressure gauge position Kamen64 Rules/Strategy 1 06-02-2007 19:15
FIRST 2007 GUIDELINES, TIPS, & GOOD PRACTICES dez250 General Forum 3 09-01-2007 20:26
Do you get to choose your startin position? Nitroxextreme Rules/Strategy 3 05-03-2005 00:44
