Go to Post Great CAD ** work! ** Cardboard Aided Design - philso [more]
Unread 02-12-2007, 17:30
OneCoolDude OneCoolDude is offline
OneCoolDude is an unknown quantity at this point
Programming help. EasyC Vex Robot.
FIXED
Unread 02-12-2007, 17:45
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: Programming help. EasyC Vex Robot.
The first thing I would look at the configuration of the analog/digital ports and whether or not you have the cables plugged in correctly. Take a look at the ultrasonic help page in EasyC and make sure everything is set up properly first.
Unread 02-12-2007, 17:54
Wow, It was a D'uh problem. I wrote 2-3 other programs on EasyC, and I thought it would just keep the same controller config. But it didnt, and I fixed it, and the ROBOT WORKS!! I am so exicted. But if anyone has any advice on the program to make it better, I will gladly take some.
Need help with ramping in VEX EasyC T. Maty Programming 4 03-11-2006 12:17
Arrays in Vex Programming Kit EasyC? gblake FIRST Tech Challenge 9 12-09-2006 17:05
Help needed with coding simultaneous movement (EasyC/VEX) bodaciousllama Programming 7 14-08-2006 17:35
EasyC-Vex Rx/motor frustrations- please help! Steve0100 Programming 10 08-07-2006 02:18
White Paper Discuss: VEX / intelitek easyC programming document dez250 Extra Discussion 3 15-09-2005 15:20
