Go to Post Stupid programmer question: where does the tread go? - Joel J [more]
Unread 03-12-2007, 00:46
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
pic: Programming prototyping board
Unread 03-12-2007, 00:47
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: pic: Programming prototyping board
Do I spy a drill motor from way back when?
Looks like you all have everything you need in case of a rainy afternoon...
What kind of power supply are you using? Where are you getting one beefy (and back EMF immune) enough to run a few DC motors?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 03-12-2007, 23:14
-q
It's been a few years since those were in use and we have a few spares in the shop via a FIRST clearance sale of sorts and this has that KOP plastic housing. I'm going to pass on your pwr supply question to our mentor who is purchasing them for this application.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 08-12-2007, 18:30
-q
Testing performed today indicates that the power supply pictured has enough amperage to run a Globe or Seat motor from years back but not enough for the Bosch drill motors. So either we add in a battery connector and lug around the lead acid cells or we switch out to the seat motor or FP
Not sure if one sees back EMF through the victor speed controllers
APS
Founder FRC 499
pic: BCR prototyping picture AdamHeard Extra Discussion 2 29-01-2007 16:58
296 prototyping RichardJames Robot Showcase 13 16-01-2007 12:38
pic: 108 Rapid Crab Prototyping evanisthat! Extra Discussion 11 14-08-2006 08:50
pic: when prototyping goes wrong Whalley Extra Discussion 13 01-02-2006 21:31
pic: Rocket City Robotics (34) Rapid Prototyping System CD47-Bot Extra Discussion 8 08-01-2004 21:13
