Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
Unread 27-11-2007, 12:43
CraigHickman
Posts: n/a
pic: 114 6wheel tensioner
Unread 27-11-2007, 12:45
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: pic: 114 6wheel tensioner
This is a fantastic chain tensioner system, hard to believe no one's replied to this in 6 months. On our prototype frame, our tensioner mounts are designed to be maintenance-free as well, but it's not nearly as elegant as this. Nice design!
GitHub
Unread 27-11-2007, 13:19
AdamHeard's Avatar
Lead Mentor
Hmmm... So it is kind of the inverse of the older style of tensioning the "west coast drive" (like 968 last year)?
I like it.
Unread 27-11-2007, 13:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I like it.
This is pretty much exactly like what 968 did in 2006, I think.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-12-2007, 20:12
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Okay, some questions...
What size and thread was the bolt y'all used for tensioning? I'm presuming the attachment bar was tapped for that bolt. It looks pretty thin, so I'm curious how many threads you had engaged to keep tension in the chain.
Did you have any problems with it vibrating loose during a match?
--Madison--
...down at the Ozdust!
Unread 02-12-2007, 23:36
CraigHickman
Posts: n/a
We just used a 1/4 20 bolt. It held fine. The plate closest to the wheel was tapped, and 1/4inch thick. The other plate is not tapped. We only had to tighten the bolts once per competition: right before any final match. It's a wonderful setup. This variation is a bit heavy, due to two bearing blocks. I've since redesigned it to only need one frame rail, as well as only one bearing block.
This design, with two bearing blocks, yields a beastly solid frame, but at the cost of too much weight. The singe block design is much lighter, though less beefy.
Are you thinking of maybe using this design?
Unread 03-12-2007, 00:07
Madison's Avatar
FRC #0488 (Xbot)
I've been working on something that incorporates a bolt for tensioning similarly to this -- the actual arrangement is quite different, but the theory is the same. Some folks on the team have expressed concern about the bolts backing themselves out, so I am just searching around for experiences with this type of system.
I've been working around a 3/8-16 bolt since it's going into plastic. Coarse, big threads are the order of the day for us.
--Madison--
Unread 03-12-2007, 07:44
We used this method on a few robots, the first I think was back in '97 or '98. The only drawback is when you run out of adjustment room, you have to remove a link in the chain. So the adjustment range needs to be a little greater than one link in length.
Unread 03-12-2007, 10:21
AdamHeard's Avatar
Lead Mentor
Are you doing this within one frame member like 968 in 2006, or 60 in various years; or are you doing it like 114?
If like 60, we used that tensioning setup with a #10 and it wouldn't vibrate loose that much. Usually 1-2 times a regional we'd check and the chain was slightly loose, we would it half a turn or so, and be good to go. We use the same concept on our with no problems (also ran it in 2007, had to tighten it about as much as in 2006).
So, short answer. No, it shouldn't loosen much and it should work just fine. Over the various years we've used this method, I've never seen it loosen so much over the course of one match to actual cause any problems.
Unread 03-12-2007, 11:25
When in doubt use a locking nut to prevent any movement. Loss of tension can be disasterous.
Unread 03-12-2007, 12:42
Madison's Avatar
FRC #0488 (Xbot)
Yes -- this is being added to an existing design that has well-tensioned chain because of the sprocket's center-center distances. Still, adjustment is .375" for #25 chain; One and a half links.
It's going into a single bearing block in something evocative of the "west coast drive". My concern for the bolt size is because the bearing block is plastic and we'll need more contact area on the threads to keep loading in a reasonable place, so we have to increase bolt size or the number of threads engaged. It's easier to achieve the former.
I am hoping to get away with a nylon bolt, so I don't know how much use a locking nut will be for us in that case. When everything is assembled, there will be no access to anything on the inside -- including a locking nut -- so that gives me pause, as well.
We were considering a method of capturing the bolt head and preventing it from rotating, but it's a bit of challenge to devise such a system that allows enough flexibility in where the bolt head lies to make using this for tensioning practical.
--Madison--
Unread 03-12-2007, 12:53
Cory's Avatar
AKA: Cory McBride
McMaster sells bolts with a nylon patch on the tip-eliminating the need for a locknut.
However, I have no idea if they work/work well in plastic.
2001-2004: Team 100
Unread 04-12-2007, 01:32
CraigHickman
Posts: n/a
I don't think a nylon lock nut or bolt is even necessary. We used this system with no locking methods at all, and it worked wonderfully.
I look forward to seeing pictures on how you all implement this!
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: 114 Tread V 2.0 CraigHickman Extra Discussion 4 08-01-2007 01:34
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
pic: 114: Stripped! CraigHickman Robot Showcase 5 04-04-2006 23:49
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
