Go to Post OMG, yet another blatant attempt by FIRST at being open and transparent! What is this place coming to?? :p - DonRotolo [more]
Unread 03-12-2007, 14:26
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Mecanum Drive - Help
By using the (much slower) sideways motion for distance movement, they effectively lowered their scoring potential.
There should be no reason a mecanum drive moves sideways slower than it does forward/backward, unless the team was using rollers that were a.) not at 45 degrees or b.) tightened to gain more forwards/backwards grip at the cost of sideways speed or C.) flawed via code that wasn't producing the maximum PWM signal when it should have been -- I saw that in a VEX algorithm at this weekend's Va. FTC tournament. In either case it was a design decision that also hurt them in their implementation, not necessarily just the driving decisions.
Ideally, mecanums should be able to produce truely holonomic drive trains; FRC simply lacks the processing on the controller to properly calculate the unit vectors for smooth movement. As a reault most teams settle for a 16-sector lookup table or dump that altogether and stick with robot-centric (normal skid + a bit of lateral sideways movement).
GitHub
pic: AM Mecanum Chain Drive MrForbes Extra Discussion 5 19-09-2007 02:44
mecanum drive system Charger_07 Technical Discussion 5 23-01-2007 19:20
Mecanum Drive Technique Dan Petrovic Technical Discussion 9 16-08-2006 20:42
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
