Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Go Back   Chief Delphi > Old Forum Archives > 1999
Unread 23-06-2002, 22:31
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Poll System Update
Posted by Nate Smith, Student on team #74, Holland FIRST Robotics, from Holland High School and Haworth, Inc..
Posted on 4/9/99 8:03 PM MST
In Reply to: Re: Poll System Update posted by Raul on 4/9/99 5:40 PM MST:
: Just a suggestion about robot info when registering: The speed at which a robot picks up floppies should not be related to what mechanisim is used. The choices imply that if you use an arm to pick up floppies and can only pick up one at a time, that is considered 'slow'. I have seen team #33 gobble up floppies as fast as anyone and they use an arm to pick them up one at a time.
: Raul
The mechanisms listed are simply general examples of what I've seen when comparing machines, and what mechanisms work at what speeds...they are by no means a definite classification. In the actual team profiles, only the selected speeds are shown, not the mechanism.
Nate
[IMG] code is Off
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Control system update RebAl Electrical 1 26-12-2002 22:36
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
idea: a semi-official coaches poll archiver 1999 8 23-06-2002 22:23
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
