Go to Post It is one thing to be a great designer, it is another thing to be able to explain what you did, how things work, and why things happen. - Andy Baker [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 04-12-2007, 15:31
Re: Lokking for older 2005-2007 posts
At the bottom of the screen, there are settings for display options, one of which is show threads from the, and a drop down. It sounds like yours is set to 100 days, and you want it set to "the beginning".
You may want to consider using the search function rather then manually sorting through threads (there are over 3200 threads in programming).
I think team 116 may have been the team that did what you are describing.
Unread 04-12-2007, 15:43
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Thanks for the quick responses. I was using search, but I couldn't remember the right key words. I was looking in the control systems forum for some inspiration, but noted that I could not see back as far as I thought I should.
I fixed my profile to eliminate the cutoff for now.
I found what I was looking for. Joe is correct, it was Team 116's Operator Interface Adapter Board.
Thanks again.
Looking forward to the 2008 Season!!!
Eric Anderson
Team 1425 - Error Code Xero
Calling for posts of divisonal stats... chrisrobin Championship Event 0 18-04-2007 18:55
pic: 2005 to 2007 TrippyMohan Extra Discussion 1 20-03-2007 19:58
Looking for a CAD program that will run on an older comp Cuog Inventor 3 10-12-2005 18:44
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Rookie teams post numbers here! Older teams look for teams to mentor here! Erodge General Forum 1 07-10-2002 13:40
