Go to Post The key is to get the WHOLE TEAM to understand that you are designing and building a robot, which is a complete system - not just a collection of mechanical assemblies stuck together. - SteveGarward [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 04-12-2007, 15:22
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Lokking for older 2005-2007 posts
I was looking for some posts that I recall regarding a cool idea for breaking out the signals from the operator interface onto a custom board so you could easily prototype up switches, leds, joysticks, pots, connected to the OI.
While searching the forums, I found that all the forums seem to start around August 2007. The archives stop at 2002.
Was there a big cleanup? Did stuff get lost? Will it be comming back in an archive?
Thanks,
Eric Anderson
Team 1425
Unread 04-12-2007, 15:30
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Re: Lokking for older 2005-2007 posts
Eric:
How did you look? There is a lot there from before August 2007. At the bottom of the list of threads there is a selecter for you to view things that have not been active in the past month. If you change the date to view in the last year, or from the beginning, you may find more.
Or do a search from the orange bar with some keywords.
Good luck!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 04-12-2007, 15:31
At the bottom of the screen, there are settings for display options, one of which is show threads from the, and a drop down. It sounds like yours is set to 100 days, and you want it set to "the beginning".
You may want to consider using the search function rather then manually sorting through threads (there are over 3200 threads in programming).
I think team 116 may have been the team that did what you are describing.
Unread 04-12-2007, 15:43
ericand's Avatar
AKA: Eric Anderson
Thanks for the quick responses. I was using search, but I couldn't remember the right key words. I was looking in the control systems forum for some inspiration, but noted that I could not see back as far as I thought I should.
I fixed my profile to eliminate the cutoff for now.
I found what I was looking for. Joe is correct, it was Team 116's Operator Interface Adapter Board.
Thanks again.
Looking forward to the 2008 Season!!!
Eric Anderson
Team 1425 - Error Code Xero
Calling for posts of divisonal stats... chrisrobin Championship Event 0 18-04-2007 18:55
pic: 2005 to 2007 TrippyMohan Extra Discussion 1 20-03-2007 19:58
Looking for a CAD program that will run on an older comp Cuog Inventor 3 10-12-2005 18:44
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Rookie teams post numbers here! Older teams look for teams to mentor here! Erodge General Forum 1 07-10-2002 13:40
