Go to Post I guess I'm a bit of an apple fanatic. - Austin [more]
Unread 28-11-2007, 09:55
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Autonomous For TECH Robots
I need to make the robots run the first 20 seconds of the match, but the robot do run for 45 secs. I am using the Quad Template and I am using Master Code v7. Does anyone else have this problem? Thank You!
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 28-11-2007, 11:42
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Autonomous For TECH Robots
If you're using both the 07-08 template and Master Code v7, you should be fine. I would suggest reloading all the code, both master and user. If that doesn't fix the problem if you can I would suggest swapping the Micro Controller and see if that fixes it. We had a problem last year where a robot would go into auto mode in the middle of a match because the Micro Controller was bad.
Unread 28-11-2007, 15:28
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Make sure no devices are in interrupts 5 & 6
If you are using easyC Pro don't put a while(1) loop in initialize
Check out Brad's Video on www.intelitekdownloads.com/easyCV2
Unread 01-12-2007, 09:41
Electrical Engineer
Rookie Year: 1995
Originally Posted by Kingofl337 View Post
Make sure no devices are in interrupts 5 & 6...
Adam,
That advise is accurate only if you are using EasyC... If using MPLAB, jumper 6 must be installed.
I was able to help John via a phone call. He was not using the very latest master code for his robot.
The very latest code for all three platforms (EasyC, RobotC and MPLAB) can be found here. FTC teams should be sure that they have the latest code installed before competing.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 05-12-2007, 16:50
Kingofl337's Avatar
AKA: Adam
We should probably see about making the two versions sync up to avoid confusion. So the jumper settings are the same, I'll talk to IFI about it....
Video Autonomous Modes of 2007 Robots Doug Leppard General Forum 12 08-08-2007 21:19
Ontario provides funding for tech based programs Jay Trzaskos Fundraising 9 31-05-2006 02:10
Fully autonomous robots? Mike Programming 29 18-01-2006 21:37
[CF]: DeVry/ITT Tech/Ivy Tech Teams Amanda Morrison FIRST-related Organizations 1 29-09-2005 00:45
Autonomous mini-robots competition tchescow Off-Season Events 8 19-07-2003 00:28
