Go to Post Having someone with as much mainstream appeal as will.i.am is a great strategy to draw large amounts of attention to a program that has been relatively hidden to the masses. - Karthik [more]
Unread 06-12-2007, 12:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: EasyC Vex Programming help in RC Mode
If your mechanism does not need a lot of power (see Mike's post), then you can limit the speed in software. First you would map the Rx Input to a variable. Since the values coming back from the transmitter range from 0 to 255, with 127 neutral, we subtract 127 so our values are now centered around 0. (Don't declare your variable as an unsigned char, use int here!)
The next step is to multiply our new value times a coefficient between 0 and 1. But since the controller only likes to play well with integers, if we want the motor to only go 60% of max speed, we can multiply ourVariable = ourVariable * 6 / 10; with replacing ourVariable with whatever you declared your variable as.
Then we add 127 back into this, and set this value to the motors. By adjusting the coefficient, you can narrow down or widen how much available speed you want to send to a motor.
Art Dutra IV
世上无难事,只怕有心人.
Programming help. EasyC Vex Robot. OneCoolDude Programming 2 02-12-2007 17:54
Need help with ramping in VEX EasyC T. Maty Programming 4 03-11-2006 12:17
Arrays in Vex Programming Kit EasyC? gblake FIRST Tech Challenge 9 12-09-2006 17:05
EasyC-Vex Rx/motor frustrations- please help! Steve0100 Programming 10 08-07-2006 02:18
White Paper Discuss: VEX / intelitek easyC programming document dez250 Extra Discussion 3 15-09-2005 15:20
