Go to Post I also would not recommend shipping the gerbils with the robot. - Stuart [more]
Unread 06-12-2007, 18:16
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
Limitless Potentiometers
Hi,
I've been experimenting with limitless potentiometers....and have found them to be a little unreliable. Has anyone else used infinite rotation potentiometers?? If so, what kind and were they reliable? We are just trying to find another sensor other than a 10 rotation potentiometer for rotation measurement. This is because we had something like 8 potentiometers break on us last year, mainly because they get locked inside due to load on the shaft . We were also thinking of encoders but are afraid of using too many interrupts and messing with the interrupts already used by sensors like the camera and gyros. Any advise?
Thanks
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
Unread 06-12-2007, 18:42
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Limitless Potentiometers
maybe try finding one of those 20 circular switches and then use some converters to so it doesnt take 20 I/O pins
Unread 06-12-2007, 20:05
Gdeaver Gdeaver is offline
FRC #1640
There are magnetic field sensors that can replace pots and encoders. Check out this device.
http://www.gmw.com/magnetic_sensors/ametes/360ASMC.html
With a simple A to D you can Know the exact position of a shaft. There is no dead band as with some continous rotation pots.
Unread 06-12-2007, 20:20
desi_technology's Avatar
desi_technology desi_technology is offline
AKA: Shahil
FRC #0176 (Aces High)
desi_technology is on a distinguished road
Send a message via AIM to desi_technology
Breaking Pots? A few years back we came up with a solution in 2005, we engineered a POT Holder and custom spring idea. Basically what happens is if you over turn the pot instead of the pot breaking if it is directly connected to the shaft and special spring will slip instead to protect the pot(the spring is connected to the pot shaft and the other end to the actual shaft). The spring is wound on a wooden cork and allows no slippage during regular use, so you don't lose any precision in your pot readings, it only activated AKA slips when the pot reaches its limit. I have posted a link below to a picture of what it looks like. In the picture look for the white color HDPE holder with a pot at the bottom of it. You can kind of see the wooden piece to the spring, but if you want more details just ask and i will try to get more pictures for you.
http://http://aceshigh176.org/drupal/index.php/v/2007/Scrimmage/100_0143_001.JPG.html?q=gallery
AWARDS:
2007- Greater Tronoto Winners Thanks To 1114, 2056
2007- Connecticut Finalists
2006- UTC WINNERS, THANKS TO 177,1124
2006- BAE FINALISTS
2005- UTC Woodie Flowers Winner
2005- UTC Engineering Inspiration Award Winner
2005- Long Island Safety Award
2004- BAE Granite State Winners
2004- Nationals Finalist Award in Newton Division
1999- Nation Champions
Visit us at:
www.aceshigh176.org
Unread 06-12-2007, 20:25
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Just this past year team 1024 used a pair of MA2 Absolute Rotary Encoders from US Digital on our drivetrain.
Seriously, I know everyone hears analog and thinks totally noise immune. Really, with a tiny bit of smart EMF design it wasnt a problem. However, I know personally I'd rather use a digital optical shaft encoder, but unfortunately our robot this past year was really fast and to get any kind of resolution out of the encoders the frequencies got rediculous at the top end, so much so it was impossible to track without losing counts.
So, hence the move the the MA2. The driver took just one evening to write, and works like a charm. Instead of having an interrupt in the multiples of KHz, we only had to sample the encoder at 100Hz. Best of all, you get the ability to handle a high top-end RPM without sacrificing low-end RPM positioning accuracy (our robot last year could position +/-0.05 inches at the frame).
Again, as long as you can do a decent EMF design to keep the analog signals from the encoders safe, they work like a charm. Definitely worth your time to at least research.
Questions? Post.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 06-12-2007, 20:26
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Have you considered how you mount your pots? It seems that if you are having mechanical problems with the pot due to load on the shaft, you need to think about how to mount it to have less load. For example, if you are using it to calibrate an arm, it is tempting to tie it directly to the axis of rotation. However, you could put a gear on the pot arm and a gear on the arm axis and use a chain (belt?) to turn the pot.
It is a bit more complex mechanically, but you decouple the sensor from the load bearing mechanicals, and you can adjust the amount of play you need from your pot by adjusting the gearing between the pot and the motion you want to measure.
I think we did that last year with our robot. We had a multi-turn pot to measure the movement of the tube lifting rack. It was mounted parallel to the top of the rack with a gear that transferred the motion of the rack to the pot. I think we lost a pot due to a collision, but never due to rack loading.
Unread 06-12-2007, 23:15
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
A few years back I experimented with continuous turn (No Mechanical Stop) Potentiometers. For my application however, the rollover from 0-1023 was too fast for the code to work with to recognize and adjust accurately for the rollover.
These are the ones I used. I found them to be reliable, and consistent.
At that I time I had obtained them from Newark-In-One.
I can't say if they still stock them or not.
Here's a link to the data sheet.
http://www.vishay.com/product?docid=...odel%20357
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 06-12-2007, 23:40
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
We have been using rubber tubing to connect the shaft of a potentiometer to a shaft that we are trying to measure the angle of rotation. If you pick the right rubber tubing, the shaft will slip if you try to rotate past the stop. We also incorporate limit switches into any arm design to insure that we don't break anything mechanical, including the potentiometer.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 06-12-2007, 23:55
DonRotolo's Avatar
Back to humble
FRC #0832
We have been playing with a Vishay/Spectrol position sensor P/N 601-1045-000 (Part No 594-601-1045 from Mouser). It outputs a smooth 0 to 5 volts in 360 degrees and is very sturdy mechanically. Only downsides are the abrupt jump from 5 volts to 0 volts at the 360/0 degree position, and the cost (about $60).
Don
Unread 07-12-2007, 00:20
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Questions? Post.
-q
Sorry to hijack the thread, but I'm wondering how you would tell what direction you moved. I don't doubt this can work very well for something that only goes under a revolution. However, let's say you moved from 100 degrees to 200. How do you know if you moved 100 forwards or 260 back?
Thanks.
Unread 07-12-2007, 00:59
AdamHeard's Avatar
Lead Mentor
I found the best method is simply to use a POT that has more turns than is required. For both joints of our arm this year, the arm would hit the frame or the ground before the shaft would break. Now, we obviously has limits so this wouldn't happen, but we never had to worry about a POT breaking.
Unread 07-12-2007, 01:20
dtengineering's Avatar
AKA: Jason Brett
Encoders don't need to be hooked directly to the RC. A little custom circuit using a PIC microcontroller (or other device... consider a VEX RC) can decode several encoder signals.
This means that while you might still use interrupts on the RC to count the rotations, they need not be as frequent as with a direct connection, nor do you need to worry about tracking the timing to determine direction using the RC. Heck, you could even have the custom circuit send a serial data pack of shaft position and velocity to the RC upon request if you really wanted to get creative.
We had a circuit set up like this for the gear tooth encoders a couple years back in the event we needed to use it, and used a similar... although simpler board from banebots with the encoders for the 56mm gearboxes this past year.
Using the banebots boards we had no... well... almost no... problems reading inputs from four encoders. For joints with less than about 270 or 300 degrees rotation, pots work great. (And sliding pots work great, too for linear applications of a few inches or so.... although now that I think of it... why couldn't a long length of nichrome serve as a very long linear pot...?) But in any case for continuous rotation, making an encoder work will be more than worth your time.
Jason
Unread 07-12-2007, 01:23
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Sorry for the hijack, but...
Have you ever looked into using WPILib?
I know you said you wanted to stay away from encoders, but WPILib makes all the interrupts you mentioned painfully easy and very hard to screw up. Our team has been using pots for the last few years, but after beginning to use WPILib, we switched to encoders with relatively few problems.
Unread 07-12-2007, 11:42
Thanks.
You choose a sampling rate such that you can never move more then 180 degrees per sample. If you see a change less then 180, you're moving forward, if you see a change greater then 180, you're moving back.
We used continuous turn pots for our drive last year very successfully. We followed the directions in this white paper: http://www.chiefdelphi.com/media/papers/1743
Unread 07-12-2007, 13:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
There are a couple of different ways to approach rotation sensing, and one you might not have thought about is a light sensor combined with a state machine. A couple of pictures of this are in the 2006 FIRST design book.
Take a light sensor that's not mounted on the rotation and have it reflect off a plate that is mounted on the rotation (or vice versa). Where you want the rotation to stop, mark it with a black sharpie. It's literally that simple, but at the same time it's not as robust as other sensing methods.
Another way to do this, if you're trying to measure drive train ticks, is to put a mark parallel to the axle shaft on a shiny part of one of your rotational pieces. This will give you only one interrupt per rotation. If you want it to be more accurate, put 2 marks to give you 2 interrupts per rotation.
The other thing you could do is ask for pictures of how others mounted their potentiometers. We only had 1 pot on our bot in 2007, but it never broke. It was mounted to the inside of 1/4 the length of a hinge, so the hinge bolt itself took most of the load.
GitHub
1 Megohm Potentiometers phrontist Electrical 9 22-02-2005 02:05
Flaky Potentiometers theDoctor Electrical 4 21-02-2005 21:08
Using Potentiometers arpus maximus Electrical 5 20-11-2004 16:45
Q about potentiometers Nick R. Electrical 13 07-02-2004 09:13
Potentiometers Ulibrium Technical Discussion 1 23-01-2002 19:41
