Go to Post Chuck Norris can be the human player and throw a Poof ball into the 3 point goal and it counts. - Andy Baker [more]
Unread 06-12-2007, 23:01
CraigHickman
Posts: n/a
pic: What happens in the offseason...
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: pic: What happens in the offseason...
your robot for next year will have a skateboard drive train? what?
Unread 06-12-2007, 23:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
CADding whatever you have sitting around, is good practice!
Unread 06-12-2007, 23:03
CraigHickman
Posts: n/a
Actually, this is CADed from scratch. It's a precision truck of my own design. Soon to be machined.
Unread 06-12-2007, 23:43
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
what angle are the base plates? are you using 8mm or 10mm axles? are the hangers going to accept standard bushing, or are they custom bushing? Are you using a pivot cup or a spherical bearing? and how are the axles attached to the hanger(e.g. pressed in, screw in or cast in)?
OUTWORK US
Unread 06-12-2007, 23:47
CraigHickman
Posts: n/a
Hey, I found another longboarder! They're 42 degree plates, with 8mm axels. They're custom bushings, and it's a spherical bearing. The axels are knurled, loc-tited, and then pressed in.
Unread 06-12-2007, 23:58
AKA: Taylor
Talking Re: pic: What happens in the offseason...
well i like the design, but i would highly suggest trying a threaded axle with a pin that fits into a hole in the axle and truck. this would allow for the strength of threads, with out the possibility of backing out. also, make sure you make a recessed cup for your bushings!!!!
reminds me of this truck, and the axle with pin thing is on this truck also
http://www.landyachtz.com/D27.cfm?PID=257&place=3
OUTWORK US
Unread 07-12-2007, 00:05
CraigHickman
Posts: n/a
Yeah, there is a slight hole for the bushings. As for the axel attachment, I'm sure that knurling and loc titing will be plenty, especially because it will be press fitted also.
Unread 07-12-2007, 00:11
AKA: Taylor
What kind of board will you be riding this on? is it drop through or top mount?
is the truck drilled for new school mounting, old school mounting, or both?
OUTWORK US
Unread 07-12-2007, 00:18
CraigHickman
Posts: n/a
It'll be a top mount, drop deck speedboard, most likely. Have yet to make it. The truck is drilled for neither old school, nor new school, yet. It's still in concept phase, so tiny details like that are on the finalize list before I got into the shop to roll these off. It'll probably be new school when it is drilled, though.
Unread 07-12-2007, 00:27
AKA: Taylor
do u post at all on silverfish? I overall like the design, are you going to sell any? they overall look like a solid skate truck. What wheels are you planing on using? anything over 75mm, you should probably consider using heat treated axles.
OUTWORK US
Unread 07-12-2007, 00:31
CraigHickman
Posts: n/a
The axels are already going to be heat treated. Yeah, I do post on SF, under the name Ironspork. There's a thread with more renders in the trucks section.
As for the wheel size, I'll probably be putting BigZigs on this, so hardened axels are a must.
Unread 08-12-2007, 16:05
Jared W's Avatar
Jared W Jared W is offline
FTC #3228 (S.P.A.M. FRC #180)
Jared W is just really niceJared W is just really niceJared W is just really niceJared W is just really niceJared W is just really nice
Send a message via AIM to Jared W
I tried reverse engineering a complete skateboard for my engineering class project on Autodesk Inventor.
I was able to do the deck, wheels, and hardwear quite easily, but when it came to the trucks I was stumped. Plus it was the end of the year so I never had time to finish it. I don't have Inventor on my laptop =(.
From your design it looks easier to make some of the edges squarer(? lol) than normal.
Nice job.
pic: This is what happens when the parts aren't in. RoboDriver1718 General Forum 4 23-01-2007 09:03
pic: What happens when the Technokats go out to play... dubious elise Extra Discussion 9 28-07-2006 17:15
pic: This is what happens...... CD47-Bot Extra Discussion 14 16-06-2004 16:25
What happens to the broken parts after competitions? Greg Needel General Forum 4 31-03-2003 01:46
What happens to the ALUMNIS??? archiver 1999 8 23-06-2002 22:02
