Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 07-12-2007, 12:17
EricH EricH is online now
Re: Controlling a Mecanum drive with two joysticks?
Originally Posted by Leav View Post
a normal joystick just doesn't have enough degrees of rotation to control a holonomic robot. so we had a couple of ideas:
    • use a two joystick design where each joystick controls the a corresponding side of the robot. this would allow full control but the exact function would need to be figured out.
This might actually be easier. Tank drive, with some code such that moving both joysticks to one side or the other causes the robot to slide. I think the main problem with a "sidewinder" joystick (other than converting it to analog) would be making sure that you don't twist it at the wrong time.
Or, a single stick using the thumb wheel to rotate (left side next to the stick) or even the button and trigger.
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
two joysticks TEAM 1436 Control System 14 03-03-2005 21:23
Controlling Solenoids With Victors Brandon_Cmpvir Electrical 20 16-03-2004 10:21
controlling with the radio Lord Nerdlinger Programming 2 17-02-2004 22:40
Two Right Joysticks??? Evil_Warlord_42 Control System 26 28-01-2004 23:59
