Re: Botka the Balancing Robot
$40 for one. It goes down to $35 if you buy 100 or more.
and is it FIRST-capable?
voltage etc? |
Looks like it. Here is the data sheet. http://www.invensense.com/shared/pdf..._Datasheet.pdf
Wow.... this never clicked in my head, but I bet some games would have some sort of challenge that could be solved via a balancing robot. It would definitely amaze the scouts and judges at least!
The problem would be making sure the robot could handle a disable command without self-destructing; some kind of kickstand would be in order, along with software that didn't allow the robot to spaz out when going back and forth between the two states (see also: 2005). I offer a tip of the hat, and perhaps also some Krispy Kremes, to any team that can pull off this kind of feat on the field. |
If you don't want to (or don't have the resources to) build your own PC board, InvenSense offers an evaluation board. $150 = not cheap.
#7
I guess you guys don't remember, I think it was the 2001 game we had to ballance our robot on a bridge with two goals. A few teams could do it with no problem back then. That was when they gave us the first gyro.
| pic: Vex 2 Wheel Balancing Robot | Tom Bottiglieri | Extra Discussion | 11 | 25-04-2006 15:19 |
| 2 wheeled balancing robot | John Gutmann | Technical Discussion | 16 | 26-08-2005 14:21 |
| Self-Balancing 2 Wheeled Robot | Mike | Robotics Education and Curriculum | 25 | 02-08-2005 15:12 |
| Self Balancing Robot in FIRST (plausible? possible? preferable?) | phrontist | General Forum | 11 | 28-06-2004 10:55 |
| THIS TIME TEAM 438 BALANCING ROBOT | archiver | 2001 | 1 | 24-06-2002 01:01 |
