Go to Post I want an inflatable playing field so 2 people can setup the competition in one hour at every event. I want it to fit in the back of my car. - Ken Leung [more]
Unread 07-12-2007, 15:31
pctopgs pctopgs is offline
None #0369
pctopgs is an unknown quantity at this point
C# and robots
Can C# work on programing robots?because i already know a little bit of C#
Unread 07-12-2007, 17:01
Electrical Engineer
Rookie Year: 1995
Re: C# and robots
On a purely theoretical level, yes. But why would you want to? It would be like hanging a picture with a sledgehammer... Overkill...
For the most part, C#, C+ and C++ are supersets containing C. While there are exceptions to any overly simplistic statement like that, you likely already know nearly everything you need to to program in C.
The same goes for Java. C is the grandfather computer language that spawned many others and is really quite simple. Review this tutorial exerpted from Kernighan & Ritchie's "The C Programming Language" and ignore all the references to interfacing with operating systems (like command line parameters, et cetera) and you will be fine.
Mike
Mike Betts
As easy as 355/113...
Unread 07-12-2007, 19:16
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: C# and robots
Also, C# works on the .NET framework, and the CLR to run. This is highly impractical to put on a FIRST robot (even if you could) due to the fact that the framework eats memory like crazy.
And it really isn't necessary. If you know C#, picking up C should be relatively painless (especially since the code for most of the robot isn't all that complex compared to possibilities in C#).
Unread 07-12-2007, 23:46
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: C# and robots
There are ways to do this, but it would require a co-processor [cough]used Windows Mobile PDA[/cough] which could run the .net framework.
Even though it is possible I don't see the advantage. Most tasks on the robot are simple, and C is very similar to C#.
Eric Haskins KC9JVH
Unread 08-12-2007, 11:53
slavik262's Avatar
AKA: Matt Kline
Re: C# and robots
Exactly my point. The .NET framework is... sluggish, to say the least, and most of robot tasks are simple. It would be much better to just figure it out in C.
Unread 08-12-2007, 16:03
Re: C# and robots
Really?
Unread 08-12-2007, 16:20
AKA: Eric Haskins
Re: C# and robots
Originally Posted by Tom Bottiglieri View Post
Good find, but I'll need to run those tests myself before I believe them. Even though I like .net.
The .net micro framework can run an ARM7 and ARM9 processors with as little as 256k of RAM.
The .net micro frameowrk also supports the same debugging experiance that you get with regular PC debugging with .net.
This is a somewhat interesting discussion about the .net micro framework.
Eric Haskins KC9JVH
Unread 09-12-2007, 00:33
slavik262's Avatar
AKA: Matt Kline
Re: C# and robots
Don't get me wrong. I love the .NET framework for a lot of things. But not so much for others. I was more referring to the amount of memory it takes up, and on a PC, it's controls are sluggish when updated. Besides, there are ways to work around floating point math, saving a lot of time on your processor.
Unread 09-12-2007, 03:01
Re: C# and robots
I'm not saying that you are right or wrong. Just don't make sweeping generalities, because there will always be someone with the facts.
Unread 09-12-2007, 15:10
FRC #0701 (RoboVikes)
Re: C# and robots
There is nothing wrong with the stats posted, and honestly C# is definitely not significantly "slower" than any other language (it is more than fast enough for any computation I've ever seen done on FIRST robots) .... the problem is that C# is usually compiled down to an intermediate byte-code rather than assembly code, this means you need to run a virtual machine which interprets the byte code. Again this is not going to be that much "slower" however there will be a memory overhead which was not shown by the tests, since they only checked floating point operations.
Theoretically you can program your robot in any language (javascript, python etc) as long you write a compiler which will turn the code into assembly. This of course is not a trivial task, but certainly not impossible.
The whole point of C# is to make it easier to develop large software projects, most FIRST robots have like 8 functions, and you don't exactly need polymorphism or all of the other things that make C# useful, so I would say there is no advantage to use C#.
If you want a challenge, try writing a LISP interpreter on the RC... it's one of the easiest languages to write an interpreter for.
Team 701
Unread 20-12-2007, 23:58
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: C# and robots
Doesn't help for FIRST really, but if you're interested in C# and robots, borrow a LEGO NXT kit from a FLL team and get a copy of the free Microsoft Robotics Studio (http://msdn.microsoft.com/robotics/). Requires a decent knowledge of the C# language and then some additional learning about the Concurrency and Coordination Runtime (CCR), which isn't quite as scary as it sounds.
Once you get going it's really fun and powerful. I took a class last summer that used it, and we got all the way to using vision recognition, (Requires a robot that you can hook a camera to, so NXTs won't work, but we just used webcams) which is made pretty easy because it's all built into MSRS.
In addition, this is what a lot of colleges and even some corporations are starting to use, so you'll have a head start if you want to keep going in robotics. Have fun!
--Ryan
Unread 21-12-2007, 00:33
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: C# and robots
I'd actually expect this to happen sooner rather than later - eventually, as people start doing more and more 'AI' typical work for their autonomous modes, they will realize the clear and inherent superiority of LISP.
(not to start a language-war or anything, but I prefer LISP to C, especially when trying to abstractly develop behaviors and writing code underneath that. LISP also has the advantage of there being multiple GP systems that are implemented in it).
//Dillon Compton
www.metalmoose.com
pic: Kids and Robots JohnBoucher Extra Discussion 8 10-10-2007 07:43
Video of Regionals and Robots natis General Forum 10 15-04-2006 21:13
pic: Robots and Pancakes CD47-Bot Extra Discussion 5 15-02-2004 11:54
Robots and Small Balls archiver 2001 6 24-06-2002 00:44
On board cameras and vision systems and robots! oh my! archiver 2000 1 23-06-2002 23:02
