Go to Post The bulk of the hardest fun you'll ever have is opening up that box in early january, and the six week of chaos that that box of parts puts you through. - Joe G. [more]
Unread 07-12-2007, 09:53
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Issues with non working victor constant orange led
Hey. Our team 2185 has been having some issues with our 2007 robot.
When we plug everything in and power on our victors for the drive train stay solid orange. We have all greens on the board, and nothing else seems to be wrong. What we thing is wrong is either something is bad with the victor or the cables are bad. We have tried multiple PWM ports on the robot interface but no luck.
Does anyone have any ideas how to troubleshoot or fix this issue? I was thinking to get a few new cables, but are the PWM cables special to first or could i get them at any electronics store?
Thanks for any help, Team 2185
Unread 07-12-2007, 10:12
Electrical Engineer
Rookie Year: 1995
Re: Issues with non working victor constant orange led
Put a printf statement into your code to display the pwm values. It is either software or the trim on your joysticks.
Mike Betts
As easy as 355/113...
Unread 07-12-2007, 10:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The lights on the victors on our 2007 robot seem to be orange also, but the robot works just fine.
Do you have a problem with the robot's functionality?
also if you're having the same problem with all victors, I would not expect all the cables to be bad the same way, all of a sudden.
Unread 07-12-2007, 11:55
Bad PWM cables (or robot DISABLED) would be indicated by a blinking orange light on the victors.
A solid light means the vistors are receiving a proper neutral control signal over the PWM cable.
Unread 07-12-2007, 12:34
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
We had the same problem.
Replacing both the pwm cable, and the victor solved it.
I think though the problem was with the PWM cable.
We had another seniliar problem yesterday, the camera didnt recieve any voltage, we replaced the PWM cable and everything if fine.
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 07-12-2007, 12:59
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Sometimes, while it might seem like the PWM cable is all the way in, it might actually not be making full contact on all pins...you might need to pull out the cable and make sure that all the pins are straight, and be careful when plugging it back in that all the pins slide into their respective spots.
Unread 07-12-2007, 17:15
Electrical Engineer
Rookie Year: 1995
Originally Posted by squirrel View Post
The lights on the victors on our 2007 robot seem to be orange also, but the robot works just fine...
To emphasize what Mark posted, this is from the IFI Users Manual:
The LED indicator will be GREEN in ‘full-forward’ condition, RED in ‘full-reverse’ and ORANGE while in neutral.
A solid orange light is exactly what you should see. A lack of functionality points to software or the operator interface...
Mike
Mike Betts
Unread 07-12-2007, 18:24
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I would check to see that your motors are plugged into the correct ports on your controller. That seems to be the problem to me... especially since it has been about 9 months since the robot was in competition. Some kid may have been looking around, pulled out a cable, and plugged it back into the wrong port without knowing.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 10-12-2007, 18:17
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
OK if your victor has a solid orange LED light and you are telling the motor plugged into that particular victor to run and it is not running you can try a few things. (just so you know if there is a solid orange LED then THE PWM CABLE IS FINE!!!)
It is receiving proper signal and it is communicating with the RC.
A few things you can check
1. Is the victor plugged in to the correct PWM signal OUTPUT spot on the RC?
2. Is the polarity correct? (+ is in + and - is in -)
3. Is the power IN from the battery plugged into the IN POWER on the victor not the out power?
Try a few of these things and let me know if that works for you.
Unread 21-12-2007, 22:27
AKA: Dani
Sorry for the really late reply. Thanks for all the help. We ended up fixing it.
The coding was messed up, we think someone got on the computer when it was open and messed with the defaults so then we were just loading bad defaults.
So we just got it coded in C by a team member.
Thanks so much for the quick replies, glad to see there is somewhere we can come for help!
Unread 21-12-2007, 22:32
popo308's Avatar
AKA: Brent
no problem
Don't throw away your non-working CH Flightsticks, repair them! Adam Richards Control System 4 03-02-2007 20:03
Non-Victor Speed Controller FourPenguins Electrical 6 31-10-2006 15:46
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Non-FIRST Tech Issues (where to place) indieFan CD Forum Support 3 22-07-2004 06:40
Non-variable Victor Control Madison Technical Discussion 16 31-01-2002 15:35
