Go to Post Honestly, no one at a FIRST competition is gonna judge you. Chances are, there are least 20 people dorkier than you. - JohnnyB [more]
Unread 06-12-2007, 10:20
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Can't Install Max 2008
I downloaded 3ds Max 2008 but cannot install the product. I get this error message:
"This installation is forbidden by system policy. Contact system administrator. C:\MaxInstall\support\msxml\msxml6.msi"
This is a buisness location that allows our FRC team to use the computer lab after hours. Our IT guy came over and disabled all security settings, but on the next try we got the same error message.
I emailed Autodesk, but I was wondering if anyone here had the same problem & solved it?
Unread 06-12-2007, 11:57
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Can't Install Max 2008
if youre running vista you may need a update, or try running the installer as an administrator (right click and you'll see it)
Unread 06-12-2007, 11:59
AKA: Kevin Thorp
I forgot to write the computers are running XP Professional and I was logged in as an administrator.
Unread 06-12-2007, 12:22
Emily Horsman
that is extremely wierd, i used to have XP and never had that problem
Unread 06-12-2007, 14:24
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Check out this thread, post #8. It sounds like it could be the same problem (except in that case it was Inventor that wouldn't install).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 08-12-2007, 17:35
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Then check out post #11 there for the solution. I can send you the file I used if you PM me. Make sure you know exactly where it is located in your Autodesk folders and then you can replace the one you have.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
2008 Offseason event MARC being moved to JUNE 28, 2008 Steve Ketron Off-Season Events 10 21-03-2008 07:55
3D MAX install on a MAC Chris_Elston 3D Animation and Competition 4 04-12-2006 12:27
Install driver natis Programming 1 20-02-2006 17:35
3ds Install rmmlg Inventor 3 29-11-2004 00:36
phpBB 2.0.10 install Ryan M. Website Design/Showcase 2 18-11-2004 19:21
