Go to Post Bumper quality is an "attention to detail" measure. Teams that get little things right tend to do better on the big things. - vhcook [more]
Unread 09-12-2007, 03:03
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: NED HELP ON BUILDING 1 OR 2 SPEED GEARBOX
Makes more sense. Is that one of yours, or did you just analyze it to death?
Edit: Yes, it is 662's 2007 robot. The discussion and original picture are here.
Edit2: Did you guys run into any issues? How much did it cost? What other info would help this team?
Team2061 sent me a PM and I provided him more details, but the short answer is that it cost about $100. It is a simple one stage gearbox using the smallest stem pinions we could find (5 tooth) and the biggest spur gear practical (80 tooth). There is one main issue with this gearbox and that is alignment. The output shaft is supported in three bearings, so misalignment can cause binding. The first year we built this design, we used solid couplers on the CIMs and this also suffered from misalignment and binding. The Lovejoy Couplers took care of any possible binding of the stem pinion gears. Just for reference, this is our first Gen of this Gearbox. http://www.chiefdelphi.com/media/photos/19829
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
pic: 114 2 speed Gearbox CraigHickman Technical Discussion 13 25-02-2007 19:41
2-Speed Shooter Gearbox JVN Technical Discussion 4 08-02-2006 13:52
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
TechnoKats 2-speed gearbox ebenhopwil Technical Discussion 17 27-06-2004 02:06
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
