Go to Post But sometimes you just wanna build something that's MFD. - Andrew Schreiber [more]
Unread 10-12-2007, 13:43
in between teams
AKA: Luke Van Oort
Re: PID vs Normal loops
I'm surprised nobody has mentioned it yet, but another good PID resource is Matt Krass's whitepaper on the topic.
Once you understand PID and start to code with it, I would reccommend writing a generalized function for PID, and then use a typedef structure to store the data for each application of the PID code. That was probably a bit confusingly worded, so here's an example. This is the PID code that ran on our 2007 robot in the offseason (you really don't want to see the code during the season... it was really bad and never worked right)
pid.c:
* FILE NAME: pid.c
* DESCRIPTION:
*  This file contains a generic PID function, and functions necessary to
*  make the PID work.
* USAGE:
*  You can either modify this file to fit your needs, or remove it from your
*  project and replace it with a modified copy.
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "pid.h"
#include "user_routines.h"
void PID_Initialize (PID_STRUCT* pid_info, int Kp_value, int Ki_value, int Kd_value, int imax_value)
//intialize ze values of ze pid structair
pid_info->Kp = Kp_value;
pid_info->Ki = Ki_value;
pid_info->Kd = Kd_value;
pid_info->imax = imax_value;
unsigned char PID (PID_STRUCT* pid_info, int error)
int P;
int I;
int D;
P = (((long)error * (pid_info->Kp))/ 1000);
I = (((long)(pid_info->error_sum) * (pid_info->Ki)) / 10000);
D = (((long)(error - (pid_info->last_error)) * (pid_info->Kd)) / 10);
pid_info->last_error = error;
if(!disabled_mode)
pid_info->error_sum += error;
if (I > pid_info->imax)
	pid_info->error_sum = pid_info->imax;
else if (I < -pid_info->imax)
	pid_info->error_sum = -pid_info->imax;
return Limit_Mix(2000 + 132 + P + I - D);
pid.h
* FILE NAME: pid.h
* DESCRIPTION:
* USAGE:
typedef struct {
	int Kp; // In tenths
	int Ki; // In thousandths
	int Kd; // In tenths
	int last_error;
	int error_sum;
	int imax;
} PID_STRUCT;
void PID_Initialize (PID_STRUCT* pid_info, int Kp_value, int Ki_value, int Kd_value, int imax_value);
unsigned char PID (PID_STRUCT* pid_info, int error);
Now what this code does is let you just write PID code once to save time. So, say I wanted to use this code to make a PID loop for both sides of the drivesystem as well as a lift. I would then add
PID_Initialize(&auton_lift, Kp_lift, Ki_lift, Kd_lift, imax_lift);
PID_Initialize(&auton_left_drive, Kp_l_dr, Ki_l_dr, Kd_l_dr, imax_l_dr);
PID_Initialize(&auton_right_drive, Kp_r_dr, Ki_r_dr, Kd_r_dr, imax_r_dr);
to initialize the PID for those robot parts. (The initialization would probably be put in the User_Initialization() function in user_routines.c. Then to run PID on these functions, all that is needed is to type
		LIFT_MOTOR = PID(&auton_lift, (Get_ADC_Result(LIFT_POT) - LIFT_UNF));
LEFT_DRIVE = PID(&auton_left_drive, (Get_Encoder_1_Count(LEFT_ENCODER) - LEFT_GOAL));
RIGHT_DRIVE = PID(&auton_right_drive, (Get_Encoder_1_Count(RIGHT_ENCODER) - RIGHT_GOAL));
which is much easier than writing three seperate PID functions. If you are controlling one thing with PID, it probably would make sense to just write your PID function specific to that thing, but if you are controlling more (I believe seven things were intended to be controlled by PID on our 2007 robot... only one actually ended up using PID though; most other uses of PID got nixed due to sensor failure or lack of debug time) then this is a much cleaner, more efficient, and faster way to code.
If you don't understand the above, don't worry. I definitely wouldn't have when I first started programming FIRST robots. So, if it doesn't make sense now, come back and read it again after you learn more about C and PID; it should make sense then. (If not, PM me)
PS: If you are familiar with an object-oriented language, the above is basically an attempt to code in C using OOP principles.
Team 1219: 2009 - Mentor
Hobbies, normal and unusual Jill1022 Chit-Chat 61 29-04-2005 08:33
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Well, is it normal for me not to be in FIRST Robotics and post here? JKis6622 Chit-Chat 3 13-03-2004 15:46
PID Control Loops ttedrow Programming 7 05-12-2002 12:03
Programming Loops Mike o. Programming 5 26-03-2002 11:24
