Go to Post If all goes well (cross fingers) we'll have a joystick for driving and one - count it, one - button: FIRE - DonRotolo [more]
Unread 24-11-2007, 02:22
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
pic: Kitbot Chain Tensioner 2
Unread 24-11-2007, 02:26
patrickbosch patrickbosch is offline
FRC #1351
patrickbosch is an unknown quantity at this point
Re: pic: Kitbot Chain Tensioner 2
Could you tell me if these are store-bought or custom made? I'm running around in my head looking for new tensioner designs, but this one is perfect.
Unread 24-11-2007, 02:29
EricH EricH is online now
Looks like a store-bought pulley with the wheel pulled and replaced with a small sprocket.
On another note, is that a cooling rack being used as a base below the chain?
Unread 24-11-2007, 02:41
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It actually looks like the one of the fittings from the end of a pneumatic piston with a sprocket added to the middle.
Unread 24-11-2007, 10:42
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
What size chain is that?
Simon Strauss
1155
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 24-11-2007, 12:08
DonRotolo's Avatar
Back to humble
FRC #0832
When adjusting the tension, how do you prevent the sprocket from rotating? I am assuming you just hold it straight, but wonder if you have some ingenious mechanism that I can't see...
Very FIRST-like: Simple but effective, with commonly available items.
Don
Unread 24-11-2007, 22:06
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We tried an approach like that in 2006, but yours is very elegant. In 2007 we gave up with it and used a super simple solution... A chuck of UHMW PolyEthylene Rod with a hole drilled in it offcenter. Rotate it into the chain and whala... Tension!! Rotate it the other way and you can remove chain off the wheel. Very simple and worked well. True there is a bit more frictional loss - but in 7 years of competing, we never had a simpler, more reliable solution. .Here's a pic..
Unread 25-11-2007, 10:42
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Just out of curiosity, where did you get those gears for the encoder setup you have? And how is the lower gear on the 1/2" Banebots shaft attached? Is it a set screw? Did it come with that 1/2" bore or did you have to enlarge it?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 25-11-2007, 11:29
Doug G's Avatar
Coach / Teacher
Those are 36 tooth, nylon, spur gears that we ordered from McMaster-Carr (pg 1012). The come stock with a 1/4" bore, which is great for the encoders, but had to bore them out to 1/2" for the banebots and add a 1/8" keyway using a broach.
Unread 25-11-2007, 16:37
FRC #1351
Ha, we had this idea as well, except it was cammed delrin for a tensioner. It appears as if it worked very well, did you have any problems keeping the tensioner from slipping?
Unread 25-11-2007, 21:13
Doug G's Avatar
Coach / Teacher
They rarely slipped. We thought we'd have to use special lock washers to keep it from slipping but never did they seemed to hold just fine. Truth be told that we always had them fully engaged which means the normal force from the chain on the tensioner is inline with the bolt, thus reducing the torque on the tensioner.
I really like using the UHMW PE. If you have never used the stuff, it feels like greasy PE.
Unread 27-11-2007, 13:49
Gboehm Gboehm is offline
FRC #1516 (Grizzlies)
Gboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to behold
Much better than my teams solution that I dare not say, cause the engineers would have a coronary...
2005 SVR Highest Rookie Seed
2005 SVR Rookie All Star
2006 WRRF Cal Games Winner
2007 SVR Winner
2007 #7 Alliance Captains Archimedes Divison
"Any sufficiently advanced technology is indistinguishable from Magic." - Arthur C. Clarke
Unread 29-11-2007, 12:30
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I thought about having a delrin cam for a tensioner, but you'd have to screw it in pretty tight to keep it from rotating over time due to the force of the chain. 1885's '08 bot will have similar tensioners to the OP's, but instead of a pully it will be a delrin block based upon what we've watched at 2 offseason events.
I like these styles of tensioners because you can directly weld the chain tensioner mounts to the frame and still have a zero-maintenance tensioning system that's very lightweight.
GitHub
Unread 10-12-2007, 15:57
The Arizona Mentor
AKA: Andrew
Ah, sorry for late responses to these questions! I haven't logged in to CD in a few months now since I graduated and am getting used to the college experience.
These are all store bought parts for the tensioner, with the exception of that metal plate which is of course from the KOP. It's simply a nylon sprocket (#25 for our chain) inside of a clevis rod end, though you might even be able to do it with the ends of the pneumatic pistons as mentioned. These ended up costing around $17 per tensioner.
Below the chain is our cart, just a nice metal cage like some metal shelving in stores.
Come to think of it I don't remember how we stopped these from rotating, but I know it wasn't really anything special, I believe they're just held on by the screw going to them.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
