Go to Post If this isn't filmed in a Tim Hortons then I'm going to be severely disappointed. - marshall [more]
Unread 11-12-2007, 00:33
CraigHickman
Posts: n/a
pic: 114's new tensioner
Unread 11-12-2007, 00:37
Aren_Hill's Avatar
Build Nifty Things
Re: pic: 114's new tensioner
I don't know if it qualifies for the tag "supersexy" but its close.
With my teams second option for whatever the game may be being 6wd most likely, Im loving seeing all these tensioner setups and chain runs being posted.
I believe this design eliminates and toe-in or out due to the fact both bearing blocks are bolted together. I've started doing the same thing in my head i did with our swerve of piecing together parts i've seen on other similar drivetrains. One of these days i may actually cad it.
A guy who likes robots.
Unread 11-12-2007, 06:47
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Did you mean 4-40 instead of 5-40? 5-40 is an awfully strange size.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 11-12-2007, 08:03
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I see a problemo!!!! If you tighten it enough, the bolt will start pushing on your collar going through the rail. I'd recommend pulling the nut part of the tensioner out a bit so you can have more travel.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 11-12-2007, 08:26
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I really like this idea thanks for sharing it I may show the team it at sometime lol
Unread 11-12-2007, 08:35
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
It looks great. I would be concerned with the tension bolt loosening. Instead of using a bolt for tensioning, you cold use a threaded rod with a hex insert at the end for an allen wrench. Then by tapping the end plate on your 2x1 extrusion, you can put another nut on so it would be double nutted.
Unread 11-12-2007, 09:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Also you could make the "halves" so they are not really halves, but one thicker than the other. Then you could just thread one of them and eliminate the round part. The hole for the tensioning bolt can go thru to the center area, since it only has to "miss" the axle.
I think it's a neat design, I also think you can refine it quite a bit more to make it more simple or easier to make. This part of the process is great fun!
Unread 11-12-2007, 10:02
What are you concerns over constantly changing your robots wheel base? I've seen a few systems that work like this.
Unread 11-12-2007, 10:19
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, this is in deed much better than the last design. For further refinement, you could turn the bolt around so it faces the opposite way, screwing into a nut that's spot-welded to the frame or an immovable delrin block. Flatten the round shaft on the bolt at one point to give 2 or 4 flat surfaces for a wrench and I think it's nearing perfection.
It's still fantastic as-is though.
GitHub
Unread 11-12-2007, 12:10
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Team 971 used a tensioner like this last year, and that really wasn't a concern for us. The amount that the wheelbase actually changes is insignificant when compared with the distance between wheel contact points.
Unread 11-12-2007, 12:16
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Impressive, it looks very similar to the tensioner that 968 used last year. Another fine example of west coast teams sharing each other's designs to the benefit of all. No wonder the quality of play has increased so dramatically!
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 11-12-2007, 12:24
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I'm all about visuals, and understanding things by seeing them... but...
uh... what is this for?
I'm actually quite lost on this one it seems.
Edit: Ok. Seeing this pic helped me see what it was going to be used for.
http://img50.imageshack.us/img50/155...ndframeur8.jpg
There is only one issue I can think of right now. When you move the bolt so the head is sticking out of the frame more to increase(?)/decrease(?) tension as it may be, wont that bolt go out of profile if your frame is not short enough to account for that? (Edit: Wait... will the bolt head move, or is it just acting like a lead screw? <-- Answered below by Nuttyman. Thanks. I was imagining something a little different than how it actually works.)
It is a cool concept.
But, I would have rather used a turnbuckle style fastener between the centers of the pillow blocks rather than something on the outside if that would be possible while not interfering with the chain itself running (presumably) inside the box extrusion.
Also, a side question for teams who run chain inside box extrusion.
Have you ever had problems of your chassis getting damaged and thus the deformed shape interfering with the chain running inside?
Unread 11-12-2007, 12:35
Nuttyman54's Avatar
Mentor, Tactician
It acts as a lead screw to slide the bearing block in the frame slot.
Unread 11-12-2007, 12:36
Originally Posted by Nuttyman54 View Post
The bolt head never moves farther out (look at where the threads engage). This works by sliding the actually bearing block in the frame, and thus moving the wheels closer or farther away from each other.
You beat me to the punch. lol Look at my edited question I popped in. I guess some issues are non-issues now. Thanks for the explanation.
Unread 11-12-2007, 13:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I think this is where you'll end up on the next iteration, Craig. The concept is sound, as I see it, and it's pretty much where I ended up a few weeks ago -- though I'm probably a few iterations farther down the road and I'm interested to see if we end up in the same place.
Also, the extant model has far more space for adjustment in the frame rail than the screw provides. You can narrow the opening to the length of your required adjustment -- .25" for #25 chain and .375" for #35.
For what reason are you intending to press your bearings in to the outside of the bearing block? I think you could change that a bit and end up with bearing blocks that can be cut in one op. instead of two.
--Madison--
...down at the Ozdust!
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: 114 6wheel tensioner CraigHickman Extra Discussion 12 04-12-2007 01:32
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
pic: 114's electronics box CraigHickman Extra Discussion 0 15-02-2006 09:35
pic: 114's robot (UNCENSORED) CraigHickman Robot Showcase 20 13-02-2006 05:37
