Go to Post Last I looked, FIRST wasn't an acronym for inspiration and recognition of robots. It was and is an acronym for inspiration and recognition of science and technology. - JaneYoung [more]
Unread 12-12-2007, 09:48
charlie1218 charlie1218 is offline
FRC #1218
charlie1218 will become famous soon enoughcharlie1218 will become famous soon enough
Re: Help with Angles and distance
XY and y arent in meters feet or inches, but in lattitude and longitude. I have a lookup table, but need to know how to create a code that say okay you have (x,Y) and (m,n) subtract those and then drag a value from the trig lookup table. Its the only way this can be done. I have no idea what blocks to use b.c as i said, i have never ever programmed before.
White Paper Discuss: Measuring Distance with Analog Potentiometers Daniel Extra Discussion 4 26-11-2008 13:52
Long distance network help needed Simon Strauss IT / Communications 16 26-07-2007 10:19
Encoder Help with VEX and MPLAB qnetjoe Programming 5 11-03-2007 21:04
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
Help with Autocad and Bryce 5 Keith Chester Inventor 0 25-03-2002 17:33
