Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 12-12-2007, 17:00
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: [FTC]: FTC Software Requirements
Originally Posted by Dave Scheck View Post
FRC controllers come without code, so downloads are required, and a standard interface is used.
If I'm not mistaken, the FRC robot controllers come equipped with a copy of the default code (same code available on IFI's site). The percentage of teams who choose not to use the default code in FRC is probably much higher than FTC though.
Unread 18-12-2007, 11:37
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Regarding re-entry into autonomous mode - low battery voltage can cause th e robot to re-enter autonomous mode.
1) Motors pull enough current to reduce the voltage below that required to run the processor.
2) Processor stops running
3) Motors turn off
4) Voltage goes up and processor reboots (into autonomous as if match were starting again)
5) Cycle repeats
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 18-12-2007, 11:55
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
At the Virginia FTC Tournament our robots were initially failed at software inspection (we were ultimately allowed to compete, but only after a match was missed by one of our teams)
Our robots (teams 226 and 369) programmed with MPLAB were using the correct version of master code and software libraries for FTC competitions. The software had performed flawlessly on a regulation competition field at the Battlefield scrimmage two weeks earlier. After reviewing the documentation since returning home it is clear that our robots were being inspected according to the criteria specified on page 7 of “Appendix 2 – Programming Information” available from the FIRST web site. The information on page 7 applies only to robots programmed using EasyC. If you look at the table of contents; pages 3-7 apply to EasyC V 2, page 8 applies to EasyC Pro, and page 9 to MPLAB. The first repeat of the master code version, the message “Autonomous(20)”, the repeat of the master code version again, and the message “OperatorControl(254)” shown on page 7 are only displayed when running a robot programmed with EasyC. These were the messages which I was told were not correctly appearing when our robot was powered up. When using MPLAB these messages do not appear. In addition, Interrupt Jumper 6 must be INSTALLED to enable autonomous when using MPLAB. With EasyC installing Interrrupt Jumper 6 disables autonomous. The software inspection procedure needs to be fixed.
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 3806 2010
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
[FTC]: Turnaround time on Official FTC forum ManicMechanic FIRST Tech Challenge 2 09-12-2007 21:14
[FTC]: 2007 FTC Game Hint Released skimoose FIRST Tech Challenge 37 23-10-2007 00:01
[FTC]: FTC/VEC First Practice Video Brandon Martus FIRST Tech Challenge 0 28-09-2007 09:47
[FTC]: Hey FTC teams, Vex and a chance to be on MTV? Rich Kressly FIRST Tech Challenge 1 12-09-2007 13:35
