Go to Post What no one knows is that I’m actually wearing fishnet stockings under this gown… as soon as they finish taking all of these darn photos I’m going to show Dave and Amanda who really has the best legs in FIRST!!! - MissInformation [more]
Unread 12-12-2007, 22:03
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
How to manipulate a variable value using an array?
I really really really want to be able to use an array to call my relays. How can i do this? See below post for what i want to be able to do.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 12-12-2007, 22:14
Re: How do i put all of the relay inputs into an array?
Better yet, how can a store variable names within an array so that when i say:
myVar = 1;
array[1] = {myVar};
array[1] = 2;
printf(myVar);
I want the displayed output to be 2
Unread 12-12-2007, 23:03
Phil Mack Phil Mack is offline
FRC #0836 (RoboBees)
Phil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to behold
You can store the address of the variable in the array, then use that address as a pointer to the value you want to print. Your array would be declared as an array of pointers.
myVar = 1;
array[1] = &myVar;
(*)(array[1]) = 2;
printf("%d\n",myVar);
Good luck,
~Phil
Last edited by Phil Mack : 13-12-2007 at 02:33. Reason: changed printf to assume myVar is an int
Unread 12-12-2007, 23:38
Re: How to manipulate a variable value using an array?
Or use a macro.
#define MYVAR        array[1]
print(MYVAR);
Unread 13-12-2007, 00:11
I need you to confirm if what I am thinking is correct:
myVar = 1; Establish the "shell" as being = 1
array[1] = &myVar; Let the 1st value of array[] = the address of the "shell"
(*)(array[1]) = 2; the * means modify/check the contents of the address of myVar
printf(*myVar); since the shell wasn't updated, the * is needed to display the contents of the address of myVar since printf(myVar) would return 1
Unread 13-12-2007, 01:01
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
 (*)(array[1]) = 2;
That would put a '2' in the memory cell pointed to by the address in array[1]. Or in this case....since the address in array[1] is that of myVar, the value of myVar would be 2, so assuming myVar is an int, your code for printing it out would be:
Which would print out '2'.
Unread 13-12-2007, 01:44
int *ptr;
int a, b;
a = 10;
ptr = &a;
b = *ptr;
Why bother with the int *ptr declaration when it has to be used again in the b= part? Is this just proper etiquette and not really needed?
Is this alright for my declaration:
int joystickbuttons[8] = {&p1_sw_trig, &p1_sw_top, &pl_sw_aux1, &p1_sw_aux2, &p2_sw_trig, &p2_sw_top, &p2_sw_aux1, &p2_sw_aux2};
And this for my looped search:
if ((*)joystickbuttons[arrayindexer[1]] == 1)
arrayindexer is just a simple array I am using for a counter.
If all this looks good then it means I finally figured this whole pointer thingie out largely thanks to this forum and Wiki.
Unread 13-12-2007, 01:51
Why bother with the int *ptr declaration when it has to be used again in the b= part? This is the example from Wiki.
int *ptr; //ptr is a pointer to the address an 'int' somewhere in memory
int a, b; //compiler chooses where these go in memory, each have an address
a = 10; //set value of a to 10
//pass a by reference to ptr
ptr = &a; //ptr now holds the address of where a is in memory
b = *ptr; //b now holds the value (use *) that ptr points to
In this case, b would be equal to a at the end.
The first line declares a pointer, which is different from a regular variable.
You can do other cool things with this, too.
void idouble(int * input){
   *input *= 2 ;
void main(){
    int x ;
    x = 5 ;
    idouble(&x) ;
    print(x);
This will print 10.
Unread 13-12-2007, 01:54
So i have to say that my array of buttons is going to be holding addresses by declaring it like this:
int (*)joystickbuttons[8] = {&p1_sw_trig, &p1_sw_top, &pl_sw_aux1, &p1_sw_aux2, &p2_sw_trig, &p2_sw_top, &p2_sw_aux1, &p2_sw_aux2};
And thus the * in the declaration indicates that the variable is "special" in that it will indeed be holiding addresses and not just numbers and crap.
And the 2nd half of the above code:
Will my above 2 pieces of code work?
I don't get some of your example:
void idouble(int * input){  Input the address and convert it to the data "input"
   *input += input ; I don't get the use of *input
void main(){
    int x ;
    x = 5 ;
    idouble(&x) ;  Call the above function giving it an address as a parameter
    print(x); I don't get how the idouble() returns x
Unread 13-12-2007, 02:23
   *input *= 2 ; I don't get the use of *input
void main(){
    int x ;
    x = 5 ;
input is a pointer. it holds an address. in this particular case, it holds the address of x. putting a * in front of a pointer means that you want to look at the value held at the address of the pointer. if input = &x, *input = x. so modifying *input will actually be modifying the value held in x. (input is a pointer, so it has no real value attached to it.) By doing this, you can modify variables in your main function without returning ANYTHING from a called function. idouble returns nothing, but because you are telling it where x is in memory and not just the value of x, you can actually change x from another function. Make sense?
Unread 13-12-2007, 02:27
Oh you sly bastard You are basically bypassing the whole naming system of variables with input and directly puting data to addresses. I like this The int *input is just the declaration of input and not the actual conversion of &x to data....that was the confusing part. I can see why google refers to pointers as "advanced c".
Can you check the code i posted above the above post to tell me if that will work fine?
Unread 13-12-2007, 20:13
This code isn't working:
int *joystickbuttons[8] = {&p1_sw_trig, &p1_sw_top, &pl_sw_aux1, &p1_sw_aux2, &p2_sw_trig, &p2_sw_top, &p2_sw_aux1, &p2_sw_aux2};
it errors me saying
I:\Robot\2007\MPLAB\Current\2007_2005\user_routine s.c:411:Error [1200] cannot reference the address of a bitfield
I:\Robot\2007\MPLAB\Current\2007_2005\user_routine s.c:411:Error [1105] symbol 'pl_sw_aux1' has not been defined
I:\Robot\2007\MPLAB\Current\2007_2005\user_routine s.c:411:Error [1101] lvalue required
I:\Robot\2007\MPLAB\Current\2007_2005\user_routine s.c:411:Error [1218] extraneous initializer values
Unread 13-12-2007, 20:31
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Well I see you have a pl instead of a p1
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-12-2007, 20:48
I fixed that but it still says
Unread 13-12-2007, 21:04
Imaginary Friend
AKA: Kevin Li
Team Role: Student
not a 100% but I think it may have something to do with the fact that the p1, p2 etc switches are defined to structures. They're defined in the C preprocessor but they were never declared as variables anywhere else(atleast not anywhere I could find)
I'm thinking that you can't do this with those variables...
Kevin Li
596 - Sciclones
turning inputs into outputs Huron Warriors Programming 4 19-04-2007 22:10
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
How to put Inventor pics on the web Andrew Schuetze Inventor 7 05-01-2005 13:59
How much time do you put into building your robot Wayne Doenges General Forum 16 29-01-2002 19:30
put effort into thread subject Brandon Martus General Forum 12 28-01-2002 19:12
