Go to Post The best legacy of this little machine is the inspiration she provided to a whole generation of future explorers who witnessed the unveiling of a planet through the eyes of a robot. - dlavery [more]
Unread 12-12-2007, 19:04
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Need help with bumpers
We used blocks of abs that were mounted to the back of the plywood with some machine screws. They fit into 2x1 aluminum tubing we welded onto the side of the chassis and then we drilled a hole vertically through it all and held it in with a clevis pin and a hairpin cotter pin. For the front and back, we drilled 2 holes that the pins went through, so the pin took the place of the bolt. Looked cleaner and was easier to remove for doing maintenance and inspection. Didn't have any problems and it held it nice and snug.
Unread 12-12-2007, 19:06
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Caution!
Bumpers have specific materials, specifications and mounting rules.
It is very important to read the section of the manual that covers this.
Violations will not pass inspection.
Hey... there may be changes for 2008, who knows?
Mike Martus
Unread 12-12-2007, 19:13
Originally Posted by Mike Martus View Post
Caution!
Unless you make custom bumpers, in which case you need to have them fit in the box and 120 pounds (or whatever it is) weight limit and you may as well make them an integral part of the robot. You still need to make sure to have them qualify as bumpers, though.
Unread 12-12-2007, 20:54
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
We weld our aluminum frame together and bolt the bumpers directly onto the frame. We use bumpers on sides only since the front and back are occupied, two bolts and two nuts per side. The bumper nuts are tightened before every match and checked after every match. Finger-tight for demos, since that's when things go wrong, and wrench-tight for matches despite things going wrong, since that's when the bumpers are actually needed. We use regular nuts because they need to come off regularly for robot repairs. The bumpers are easy to remove and very sturdy.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 12-12-2007, 22:14
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Originally Posted by 114ManualLabor View Post
Accessibility has always been an issue for us. This season, we're going to have a new setup. Imagine the meshing section of a hinge, but all square. Put several of these along the bumper, so bolts can drop in from the top. If this isn't that clear, I'll throw a CAD up in a few minutes...
Edit: Image 1 shows the two separate.The bottom section of the plate is threaded. When put together (image 2) the bolt can be dropped into the hole, and threaded in. This should allow us to change out from red to blue bumpers quite easily based on which alliance we're on.
We like the idea but hear was are idea of getting them mounted to the frame without the huge block that needs to be mounted to the robot. Basically we are using the robot frame as that piece.
Name:	bumper mount.gif
ID:	5840  Click image for larger version
Name:	bumper mount2.gif
Unread 12-12-2007, 22:20
Jeff K.'s Avatar
Hmm..now what?
Caution!
The inspectors said the blocks were just ways of mounting it, and it did not exceed the 15 lb weight limit or the 3oz/in^2 limit. They were more efficient, and the inspectors and judges like the design.
Unread 12-12-2007, 22:48
dtengineering's Avatar
AKA: Jason Brett
If you are using the KOP frame we had good luck with a technique that is probably in the CD image archive somewhere... at least that is where i think we got the idea from.
Use an eyebolt. If you pick on the right size (1/4" seems to work nicely) you can just run a bolt through the KOP frame rails and eye of the eyebolt to hold it together.
To screw the eyebolt into the bumper we took a small piece of 1/4" band iron, drilled and tapped a hole for the eyebolt, along with a couple of small screw holes.
We drilled a hole in the plywood for the eyebolt to pass through, then screwed the band iron into place on the inside of the bumper.
This worked well.
Jason
Unread 12-12-2007, 23:40
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
I was thinking of velcro, but there are spacific rules on how it should be bolted on. My question to those rules are: we want to build a round robot, can we make our bumpers in a circle? Making our own plywood in a curve would not be a problem. How far outside the robot frame can the plywood be mounted? I know that the bumpers can only be so thick but dose it have to be up tight to the robot?
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 13-12-2007, 00:10
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Last year, with 4 seperate bumpers, we used 1/4-20 carriage bolts (large, smooth button head backed by a square shank before the threads begin) through a thru-hole in the spec-size plywood--4 bolts for the longer sides, 2 for the front/back. The square shank bites into the plywood and keeps the bolt from turning while being tightened. The bolts ran through holes drilled into the side frame members (1.5"x1.5" welded aluminum tubing frame) and fastened by wing nuts that are hand tightened (i.e. no tools). We used lexan panels for side shielding on the base frame held on by velcro, which allowed us to rip off the panels and have easy access to the wing nuts for quick removal of the bumpers. We usually checked between matched to make sure none of the wing nuts loosened as part of our pre-match checklist. There were some doubters at first on the wing nuts, thinking they would loosen and fall off during a match, but we didn't loose a bumper (or a nut) all season. The only issue we had was placing the bumpers back on and getting 4 bolts through the blind holes on the inside of the frame rail--takes a little practie to do it quickly.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 13-12-2007, 00:23
Originally Posted by M. Mellott View Post
Last year, with 4 seperate bumpers, we used 1/4-20 carriage bolts (large, smooth button head backed by a square shank before the threads begin) through a thru-hole in the spec-size plywood--4 bolts for the longer sides, 2 for the front/back. The square shank bites into the plywood and keeps the bolt from turning while being tightened. The bolts ran through holes drilled into the side frame members (1.5"x1.5" welded aluminum tubing frame) and fastened by wing nuts that are hand tightened (i.e. no tools). [. . .]The only issue we had was placing the bumpers back on and getting 4 bolts through the blind holes on the inside of the frame rail--takes a little practie to do it quickly.
We had the same system, but used two on each of the 5 bumpers (one per side, two for the front). We also labeled the bumpers to show where they went and which way. Took 5-10 minutes, maybe 15. No wing nuts though.
Unread 13-12-2007, 08:10
popo308's Avatar
AKA: Brent
We originally had a nice bumper mounting system but then we realized the bumpers could not go off the group with are robot. So we mounted them to the bottom of the legs. Still a pretty good system but then we ended up talking off are lifts for a better system and we really didn't have time to prepare anything else so are last system was some wood screws through the frame rail into the bumper... It worked but it was kind of just thrown on there so next year hopefully we can get a system down good.
Unread 13-12-2007, 08:13
The 2007 rules do not specifically address a round robot base. In the robot section of the rules, Rule 37 gets very specific about bumper design. Those bumpers that meet the criteria may be weighed separately from the robot weight. Those bumpers that do not, cannot qualify for the exclusion and must be weighed with the robot. I would put this question to the Q&A as soon after kickoff as you can IF you still plan to use a round base after the game is announced. Decisions made on robot design before kickoff may not be the best fit for game play after kickoff.
I need help with plastics mechanicalbrain Technical Discussion 13 14-06-2006 11:15
Need help with my code jaywion Programming 9 20-03-2004 11:32
Need help with beacons magical hands Programming 2 11-02-2004 21:48
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
Need help with C++ Tton Programming 7 04-11-2003 19:15
