Go to Post Why does 1114 have to be good at everything? ;) - Justin Montois [more]
Unread 13-12-2007, 18:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Limitless Potentiometers
ok, I fibbed....we did the surgical tubing trick last year, this year we used a short piece of rubber automotive fuel line. The concept is the same.
The AM transmissions have a shaft with an end that is exposed, and turns with the output sprocket. We drilled and tapped the end of the shaft, then made a short piece of metal 1/4" diameter with a thread sticking out the end, which screws into the transmission shaft. Then just slipped the tubing over this short shaft and over the encoder shaft, and made a mounting bracket for the encoder. A lathe was used to drill the hole and make the adapter shaft.
The picture shows the mounting and protection for the encoder, and if you look close you can see a red tube clamp in there...the tube was not a very tight fit on the shafts.
1 Megohm Potentiometers phrontist Electrical 9 22-02-2005 02:05
Flaky Potentiometers theDoctor Electrical 4 21-02-2005 21:08
Using Potentiometers arpus maximus Electrical 5 20-11-2004 16:45
Q about potentiometers Nick R. Electrical 13 07-02-2004 09:13
Potentiometers Ulibrium Technical Discussion 1 23-01-2002 19:41
