Go to Post Who knew a single variable could be so deadly? - 3DWolf [more]
Unread 13-12-2007, 21:25
in between teams
AKA: Luke Van Oort
Re: How to manipulate a variable value using an array?
The problem is what MPLAB says it is, you cannot reference (aka have a pointer to) a bitfield, relay outputs and, I assume, joystick switch states are stored in bitfields.
Team 1219: 2009 - Mentor
Unread 13-12-2007, 21:28
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
I know they are defined in ifi_aliases.h with the #define. So how do I get them out of bitfields? Do i need to "redeclare" them as ints?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 13-12-2007, 21:44
in between teams
AKA: Luke Van Oort
When I was trying to write a generalized, modular library for FRC robots (something like WPIlib, but not as high level), I ran into this same issue, but with relay outputs. My solution was to use a structure for storing the values then, at the end of the program loop, call a function that assigned the values in the structure to the actual relays. I think you could do something similar in your case; for example, you could just assign the values of the switches to the various variables in your array at the beginning of every program cycle.
Unread 13-12-2007, 22:54
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I don't think you can redefine them to an INT since it's using a structure.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-12-2007, 23:29
Phil Mack Phil Mack is offline
FRC #0836 (RoboBees)
Phil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to behold
cannot reference the address of a bitfield
Each of these names refers to a single bit, not a byte. Because each symbol is referring to a bit and not a byte, an address is insufficient to identify the symbol. The wikipedia article http://en.wikipedia.org/wiki/Bitfield explains the concept very well.
You must look to where the bit field is defined, and manipulate the struct. However, that seems somewhat counter to what you are attempting.
~Phil
Unread 14-12-2007, 00:17
So much for elegant coding...
But i think lukevanoort's workaround will work, just as long as I put it all in a separate function. My goal with this was just to clean up a billion if-thens into a for loop but i guess a if-then function will make the code easier to read anyways.
turning inputs into outputs Huron Warriors Programming 4 19-04-2007 22:10
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
How to put Inventor pics on the web Andrew Schuetze Inventor 7 05-01-2005 13:59
How much time do you put into building your robot Wayne Doenges General Forum 16 29-01-2002 19:30
put effort into thread subject Brandon Martus General Forum 12 28-01-2002 19:12
