Go to Post 15 thread derailment points - EmileH [more]
Unread 14-12-2007, 10:00
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Printf's cause code violation
Whenever there is a printf statement in code the code violation light blinks slowly. It happens regardless of what variable types I'm printing, or even if its just text. Has anyone else had this problem?
This is on the 2006 controller using MPLAB + IFI Loader.
I have the proper serial port selected in IFI Loader, and Baud rate is 115200. Error occurs regardless of where the printf is.
Unread 14-12-2007, 10:26
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Printf's cause code violation
I've seen this before if the loop is too fast it can make the processor angry.
We saw this in early testing when we wrote the first version of easyC
Add a small delay in the loop and see if that helps.
Unread 14-12-2007, 12:47
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Can you post the code that is causing the issue?
If not, I think I had an issue like that when I switched to Kevin's code, but I don't remember what I did to fix it.
Eric Haskins KC9JVH
Unread 14-12-2007, 17:26
Kevin Watson's Avatar
La Caņada High School
FRC #2429
If you're using my serial port code, a sure fire way to get the red-light-of-death when you send data is to not properly configure the interrupt service routine in user_routines_fast.c.
-Kevin
Kevin Watson
http://kevin.org
URGENT - Code Violation CPress Programming 5 09-02-2007 23:26
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Code Violation when testing chris_chen Programming 0 24-01-2006 20:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
code violation...need help Vince lau Programming 4 20-02-2004 16:31
