Go to Post I've been busier than a hog farmer at feedin' time. - Andy Baker [more]
Unread 13-12-2007, 16:14
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
EasyC master code issues
I am currently in the process of programming our two vex robots, one of which needed a master code update. I am having a problem loading the code onto the controller. It put itself into the state of solid program light, which does not change when I remove the serial cable, turn it off, etc. but will not respond to any attempt to load the master code onto it (computer says it cannot find controller). However, the same computer and programming cable work fine for downloading normal programs onto our other vex controller, which already has master code v7. Do you have any suggestions as to how to get the master code onto our controller?
Thanks
Unread 13-12-2007, 21:03
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: EasyC master code issues
Did you use the red cable to tether the joystick board (while it is turned on) to the robot rc board and set it to PROG mode and then dl the code? I am not sure about vex, but for FRC you have to do this. Downloading code doesn't require the tether cable.
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 14-12-2007, 11:28
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
I had a problem like this when I was messing around with vex once.
Try re-downlaoding the default code that the brain had preprogrammed in it when you got it, you can find it in EasyC. Then check to see if the default code works. Test the motors and make sure they respond to the joystick and what not. If it does go ahead and update the master code. After you do that re-downlaod your code back into the brain. If all goes right it should work again.
If it doesn't work try downloading the defective code into the robot that already has the v7 in it. If the same thing happens it may be something in the code, but I don't think that would be the problem.
-Sam
Master Code gabrielse Programming 1 28-02-2007 14:30
Master Code The Vrooman Programming 8 07-02-2007 17:23
HELP!!!! EasyC Compiling Issues Wbrown0389 Programming 8 29-01-2006 09:18
Master Code 11? SteveO Programming 5 22-04-2005 19:48
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
