Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 14-12-2007, 08:42
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
pic: Robostang's Analog Sensor test software
Unread 14-12-2007, 08:43
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: Robostang's Analog Sensor test software
Don Don? Ahhhh...... Don Don...
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 14-12-2007, 09:08
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
The right side of the Results area is cut off for me. Ill post a screenshot soon.
Unread 14-12-2007, 11:42
AKA: Don
What exactly do you mean by cut off. It might just be that you are using a small screen or low resolution so windows makes the form to fit the screen. Just drag the bottom right corner of the window to the right and it should fix your problem.
-Don
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
Unread 14-12-2007, 12:04
Team 2021 Captain
AKA: Chris Davidson
Im running 1024 x 768 and it will only allow you to make the window so big.
Unread 15-12-2007, 11:01
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Yay it's an oscilloscope...
Hmm... maybe if your programming group looking for another project, you could do variable timebase and triggers (remember the 18F8722 has two programmable analog comparators you could use for a level-programmable trigger).
What I really want to know is: How on earth did you get .NET to let you access a serial port! I thought they discontinued that.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 15-12-2007, 14:26
steve0o's Avatar
steve0o steve0o is offline
FRC #0195
steve0o will become famous soon enough
Same with me.
http://i10.tinypic.com/6xaed8h.jpg
Unread 18-12-2007, 21:21
AKA: Mason Falk
I believe that our team will be coming out with a new beta 2 version with that problem fixed.... Sorry about the problem, and check back soon to see if the new version is up....
Northville, MI USA
Unread 20-12-2007, 00:42
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
[offtopic]
The 1.1 framework allows you to access the serial port via interop. The 2.0 framework supports it via managed code in the System.Net namespace of the FCL.
[/offtopic]
Unread 20-12-2007, 09:34
Phil Mack Phil Mack is offline
FRC #0836 (RoboBees)
Phil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to beholdPhil Mack is a splendid one to behold
Originally Posted by seanwitte View Post
[offtopic]
[/offtopic]
And API calls have always been available, which is still the way to have the most control over the serial port.
~Phil
Unread 22-12-2007, 23:50
AKA: Don
I released an update to the software. Just go to the link I posted originally and reinstall. The installer should overwrite all the original folder's (assuming you select the same path). I don't know what is causing this problem and I don't know if the updated version will fix anything because I don't know the problem. I tried installing the software on multiple computers before I released it and I never encountered this problem except for when I tried the software on my old laptop and even then I was able to drag out the bottom corner of the window.
-Don
Team 548:
Unread 23-12-2007, 09:55
None #0116
I haven't run the software, but the issue is caused by the size of the controls on the form. The graph is too wide to fit on the screen at smaller resolutions. You need to anchor the graph at the top,bottom,left,right and anchor the group box only on the left. The graph will resize as you change the size of the window, but the group box will stay in place. Check the minimum width and height as well to make sure the dialog can be sized for a lower resolution. Plan B would be to drag the graph control into a panel with the scroll bars enabled.
You can verify the fix by changing the screen resolution to 1024x768 and make sure the content is visible.
SONAR Sensor Software Driver MikeDubreuil Programming 55 08-03-2008 11:03
pic: Test/Training Bot Rob2713g Extra Discussion 9 25-08-2007 15:37
pic: 1662's test tranny 5 M4 Sherman Technical Discussion 4 17-06-2006 01:44
Help me test scoring software? devicenull FIRST Lego League 4 06-10-2004 21:11
How do we Test our Beacon and Sensor Matthew_H Technical Discussion 7 07-02-2004 15:42
