Re: Mounting of drive system
The easiest newbie way to do it is to mount the wheel on bearings on a "dead" axle that is just a bolt thru the frame. The sprocket then bolts to the wheel.
Whether or not you need blocks to mount the dead axle, depends on the design of your frame. The kit frame has flanges with holes in them designed for a bolt type dead axle. If you use that extruded stuff then you may need to make blocks or angled plates to mount the axle. With a live axle, connecting the sprocket you can buy hubs, most teams who use a live axle make most of the parts themselves, it's not really a newbie appropriate thing to try unless you have good help. here are some of the hubs, the keyed and hex hole type are what you might use http://andymark.biz/hubs.html Last edited by MrForbes : 14-12-2007 at 21:09. |
| Drive Mobility System | Kam-AL | Motors | 7 | 11-01-2006 19:17 |
| Best Drive system | rcubes85 | Control System | 8 | 12-01-2005 22:32 |
| pic: Drive System | CD47-Bot | Robot Showcase | 3 | 27-02-2003 14:11 |
| DRIVE SYSTEM | archiver | 2001 | 6 | 24-06-2002 02:30 |
| Drive System | archiver | 2000 | 6 | 23-06-2002 22:57 |
