Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 14-12-2007, 21:09
in between teams
AKA: Luke Van Oort
Re: Mounting of drive system
Originally Posted by neoshaakti View Post
I'm sorry Im a nub, but does dead-axle have anything to do with using pillow blocks?
Nothing really. What I'm talking about is a block of aluminum with a hole drilled partway though (like halfway maybe) so it can hold an aluminum shaft as a dead axle. Then, the block is mounted to the robot with bolts and its height can be adjusted with shims. Not really a pillow block in the traditional sense, but similar.
Pillow blocks are quite expensive on mcmaster-carr (about 30 bucks a piece)
is live-axle a more economical choice?
Generally no. A bolt through a hole in the frame can serve as a dead axle, with live you need keyed/hex/spline/etc shafts, bearings, pillow blocks, so on.
and with a live-axle, would you have to connect the sprocket to the shaft?
Usually yes. If you used gears for power transmission, you'd connect those to your shaft.
sorry for the nub questions
Nothing to be sorry for, everyone was a newbie sometime.
Team 1219: 2009 - Mentor
Drive Mobility System Kam-AL Motors 7 11-01-2006 19:17
Best Drive system rcubes85 Control System 8 12-01-2005 22:32
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
DRIVE SYSTEM archiver 2001 6 24-06-2002 02:30
Drive System archiver 2000 6 23-06-2002 22:57
